Saph 4x4 Engine Mount.
Old Jul 12, 2007 | 11:37 AM
WD Pro's Avatar
WD Pro
Default Saph 4x4 Engine Mount.
Which one breaks first, inlet or exhaust side ?
Can it be changed by just jacking the engine enough to remove it or are there other things that need to be disconnected / removed ?
Cheers for any replies.
WD
Old Jul 12, 2007 | 12:03 PM
silky16v's Avatar
silky16v
Get on That!
exhaust side normally
best way i found to change was to jack engine up loosen the mount then removed the mounting arm from the block.
then fit new mount place engine mount over the new mount and fasten back onto the block (use some lock-tight) than fasten mount back onto the cross member just remember the crossmember is alloy so be careful when refitting the bolts
oh i've found the colins mounts the best
Old Jul 12, 2007 | 12:20 PM
RS500/364's Avatar
RS500/364
aGREE ITS ALWAYS THE ONE THAT GOES SAME AS THE DRIVESHAFT ON THAT SIDE !!
Old Jul 12, 2007 | 01:51 PM
Andreas's Avatar
Andreas
How come and what have you compared it with?
Always nice to hear a mini review and just not a short statement
Old Jul 13, 2007 | 12:07 PM
WD Pro's Avatar
WD Pro
Thanks guys - job for the weekend, is it stops pissing down
Old Jul 13, 2007 | 01:33 PM
silky16v's Avatar
silky16v
Get on That!
compared to the vibratechnics 1's the collins 1's aren't as harsh and look nicer 2
Old Jul 19, 2007 | 11:55 AM
WD Pro's Avatar
WD Pro
Job done, spot on advice.
Cheers,
WD
c20tbo
Aug 17, 2015 10:19 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
Old ford
Jul 31, 2015 06:50 AM
