Removing Window Tint
Old Jul 11, 2007 | 06:33 PM
BlueFiesta85's Avatar
BlueFiesta85
Default Removing Window Tint
what is the easiest way to remove window tints, as i tried with a knife but ill be at it all week
anyone have a simple and easy solution?
Old Jul 11, 2007 | 06:34 PM
Trist's Avatar
Trist
Single edge blade warm soapy water
Old Jul 11, 2007 | 06:39 PM
BlueFiesta85
is there no solution/sustance of some kind that would maybe dissolve the film away?
Old Jul 11, 2007 | 10:49 PM
Trist's Avatar
Trist
no but warm water will slightly lift the tacky glue used to stick it on.
Old Jul 13, 2007 | 06:47 AM
syko2005's Avatar
syko2005
burning oil
i work with glass as i make double glazing. try some fine wire wool and also try somewhere like b&q see if they sell upvc cleaner. its a solvent cleaner we use it at work and it cleans glass mint. we buy it off a supplier but im sure you can get similar stuff from diy shops.
Old Jul 13, 2007 | 08:47 PM
Oranoco's Avatar
Oranoco
I gave up trying to remove it so just changed the windows
Old Jul 14, 2007 | 02:14 AM
SafeChav's Avatar
SafeChav
Surely warming it with a hairdryer or similar will make it soft so it peels off cleanly?
And then you want a tin of lighter fluid - goldy like stuff for removing sticky
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
