Removing Window Tint
what is the easiest way to remove window tints, as i tried with a knife but ill be at it all week
anyone have a simple and easy solution?
Originally Posted by BlueFiesta85
is there no solution/sustance of some kind that would maybe dissolve the film away?
burning oil
i work with glass as i make double glazing. try some fine wire wool and also try somewhere like b&q see if they sell upvc cleaner. its a solvent cleaner we use it at work and it cleans glass mint. we buy it off a supplier but im sure you can get similar stuff from diy shops.
Surely warming it with a hairdryer or similar will make it soft so it peels off cleanly?
And then you want a tin of lighter fluid - goldy like stuff for removing sticky
chowfornow
14
05-01-2019 09:01 PM
