High emmissions
Old Jul 11, 2007 | 06:20 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default High emmissions
Went to the MOT today with the cossie and CO reading was 8.6%. Car drives fine. Put the CO back towards the required 3.5% max. and passed the MOT. But the car felt than like it needed more fuel to drive smoothly so I turned the CO screw back.
Before the MOT I put a new TPS, CTS, ATS and map sensor in it. Renewed the oil and plugs (071's). Checked the timing, vacuum and fuel pressure. Done this all because of this high CO problem.
I cant figure out why it has to have a so high CO value at idle to drive smootly.
Its a 1991 4x4 non-cat, msd chip, greens etc.
Anybody got a hint for me what it could be?
Old Jul 11, 2007 | 07:51 PM
I did the same with my car for the mot i turned the emmisons down got it though its test then turned it up again.
Old Jul 12, 2007 | 11:24 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Yes, but it shouldnt be that way, should it?
Old Jul 12, 2007 | 11:42 AM
need4speed00001's Avatar
need4speed00001
Have you set the tps up properly?Mine was on 8.5% on idle and ran ok but with the tps set correctly it went down to 1.5%
Old Jul 12, 2007 | 01:23 PM
costina's Avatar
costina
Live long and prosper!!
MSD closed loop 0.7% Co
Old Jul 12, 2007 | 02:13 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Base setting is 45 Ohms so that must be ok.
Old Jul 12, 2007 | 08:51 PM
DD's Avatar
DD
HOW DO YOU SET THE TPS?
Old Jul 12, 2007 | 09:16 PM
cosy trav's Avatar
cosy trav
the mot centre i take mine to puts another car through the immissions test so it passes all the time .
Old Jul 13, 2007 | 07:27 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Well, put the new TPS on the throttle body and adjust it with a multimeter so that the value was about 40 Ohms. Than tightened the two screw and put it all back together. After that I measured the value at the connector at the ECU and it says about 45 Ohms.
What is the correct way in your opinion to do this?
Old Jul 13, 2007 | 07:52 AM
need4speed00001
To set the throttle pot ,follow this guide.
1) Ensure ignition is OFF.
2) Remove rear of ECU plug cover and insert plug back into ECU.
3) Turn ignition back on (do not start engine)
4) THROTTLE CLOSED:
4x4: Check for DC voltage less than 0.5V between pins 11 and 17.
5) THROTTLE FULLY OPEN:
4x4: Check for DC voltage greater than 4.5V between pins 11 and 17
Old Jul 13, 2007 | 09:24 AM
costina's Avatar
costina
fuel pressure??????
Old Jul 13, 2007 | 11:52 AM
DD's Avatar
DD
4) THROTTLE CLOSED:
What about a 2wd? and what's the 45ohms thing? is that measured at TPS plug? if so which pins? open or closed throttle?
cheers
Old Jul 13, 2007 | 05:58 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
4) THROTTLE CLOSED:
Yes, also done that after the resistant check. Value at closed throttle is 0.2 Volts and at open throttle 4.76 Volts.
Old Jul 13, 2007 | 06:00 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Originally Posted by costina
fuel pressure??????
Like I already wrote, have checked this. At idle with vacuumpipe connected it's 3 Bar.
Old Jul 14, 2007 | 02:43 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
4) THROTTLE CLOSED:
Strange part here is that I have got a service manuel were this is discribed as 'at idle you should have around 0.6 Volts'. But I am not sure its a manual made by Ford.
What I do find interesting is what is matters if the value at idle is more to zero than to the 0.5 Volt. Mines at 0.2 Volts. What differents could this make in the CO adjustment?
Old Jul 14, 2007 | 03:21 PM
costina's Avatar
costina
try your old cts ive had a few which were out of range
Old Jul 14, 2007 | 03:24 PM
billynocar's Avatar
billynocar
ours is 8.5 for the time being the brainey 1 says it`s been set up like that to stop it underfueling
still passed mot when he explained why it was high the guy went OK
as we have to get it set up again cos we found a couple of small oil leaks we will do the lot together
Old Jul 14, 2007 | 05:20 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
At the local MOT station I go to that doenst matter. It should be under 3.5 % no matter what. And I also want to find out what it causes.
Had tried 2 old CTS before I bought a new one. all are in range..
Old Jul 15, 2007 | 09:51 AM
cos jon's Avatar
cos jon
This is quite interesting, my escort suddenly went up to 8%CO. I have had a new TPS fitted too.
Old Jul 15, 2007 | 07:06 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Yes, me too. I like to know what values (ohms and voltage) people have at their connector on their ECU that dont have a high CO. Somebody who can tell this?
boeb
Jan 9, 2020 05:11 AM
Kam B
Sep 30, 2015 01:32 PM
