Halfords BOGOF on fully synthetic oils!!!
Old Jul 11, 2007 | 12:14 PM
Mark 3D's Avatar
Mark 3D
Moderator
Default Halfords BOGOF on fully synthetic oils!!!
ok im no oil expert but i usually use Millers in my 3 door.
anyway..... have just been into Halfords and see that theyre doing buy one get one free on 5 litres of fully synthetic oil.
The one i was interested in was their 5w/50 "Motorsport" Oil which they describe as being suitable for track days or "enthusiastic driving"!!
anyway its 31.99 for 10 litres at the moment at i was wondering if anyone had experience of this oil as if its any good then 31.99 for 10 litres is a bit of a bargain!!!
link:
http://www.halfords.com/webapp/wcs/s...tegoryId=77306
for info i want to put it in my 3 door running apoprox 310BHP.
Cheers,
Mark
Old Jul 11, 2007 | 12:18 PM
Additional Information link dont work
Old Jul 11, 2007 | 12:19 PM
Mark 3D's Avatar
Mark 3D
Moderator
It should do m8, I just clicked on it and it worked!!
Old Jul 11, 2007 | 12:22 PM
Tangodeltasierra3's Avatar
Tangodeltasierra3
Bargain, its probs made in same batch as Millers or summat anyway
Old Jul 11, 2007 | 12:25 PM
Mark 3D's Avatar
Mark 3D
Moderator
i wasnt sure what 5w/50 meant?
I usually like a slightly thicker oil in the cossie.
the other one they have is their standard synthetic which is 5w/40
could someone tell me which of the two would be more suitable?
Old Jul 11, 2007 | 12:29 PM
Wont open on my pc
Old Jul 11, 2007 | 12:35 PM
ballin's Avatar
ballin
5w50 is better than 5w40 for trackdays
Old Jul 11, 2007 | 12:37 PM
Mark 3D's Avatar
Mark 3D
Moderator
I dont ever use the car on track but i do drive it "enthusiastically" sometimes!
Old Jul 11, 2007 | 12:39 PM
OldDan's Avatar
OldDan
What if your car says run on 5w30... Are you safe putting 5w50 in?
Ridgey's Avatar
Ridgey
Hmm.. think i'll stick to Mobil 1 15w50 from Matt Lewis at £40 odd pounds for 10 litres.
Never seen a 5w recommended for a cossie by anyone !!!! Awaiting to be proven wrong
Old Jul 11, 2007 | 12:41 PM
Ridgey's Avatar
Ridgey
Dan NO
50 is to thick for modern Ford engines stick to 30. Otherwise you could have loads of problems, Ford found this when the Mondeo first came out with the Zetec and they used 40 oils. Later changing the recommendation to 30.
Old Jul 11, 2007 | 12:43 PM
tregmatt's Avatar
tregmatt
dont it say 15,50 not 5,50
Old Jul 11, 2007 | 12:45 PM
Mark 3D's Avatar
Mark 3D
Moderator
yep the description does but it says 5w/50 on the bottle.
Old Jul 11, 2007 | 12:53 PM
OldDan's Avatar
OldDan
Originally Posted by Dave Ridge
Dan NO
Cheers Dave
Old Jul 11, 2007 | 01:04 PM
Mark 3D's Avatar
Mark 3D
Moderator
Found this:-
VISCOSITY
Most oils on the shelves today are "Multigrades", which simply means that the oil falls into 2 viscosity grades (i.e. 10w-40 etc)
Multigrades were first developed some 50 years ago to avoid the old routine of using a thinner oil in winter and a thicker oil in summer.
In a 10w-40 for example the 10w bit (W = winter, not weight or watt or anything else for that matter) simply means that the oil must have a certain maximum viscosity/flow at low temperature. The lower the "W" number the better the oils cold temperature/cold start performance.
The 40 in a 10w-40 simply means that the oil must fall within certain viscosity limits at 100 degC. This is a fixed limit and all oils that end in 40 must achieve these limits. Once again the lower the number the thinner the oil, a 30 oil is thinner than a 40 oil at 100 degC etc. Your handbook will specify whether a 30, 40 or 50 etc is required.
So the question still remains.......will 5w/50 be alright to run in my cossie!!
Old Jul 11, 2007 | 01:26 PM
RS500/364's Avatar
RS500/364
jUST TO SAY GROVE USED 5/50 IN MY rs500
Old Jul 11, 2007 | 01:29 PM
Mark 3D's Avatar
Mark 3D
Moderator
and all seems ok?
Old Jul 11, 2007 | 02:01 PM
foreigneRS's Avatar
foreigneRS
Testing the future
Found this:-
VISCOSITY
that is generally correct, but this bit..
..is bollocks. a lower number means a lower viscosity at the lower test temperature - nothing more. whether a low or high viscosity is better for your engine is another thing
Old Jul 11, 2007 | 02:18 PM
Mark 3D's Avatar
Mark 3D
Moderator
i just want to know if people would reccomend using 5w/50 in a cossie!!?
Old Jul 11, 2007 | 02:43 PM
Cawood's Avatar
Cawood
dont bother
i just ordered 10 litres of mobil 1 motorsport of matt lewis for £55 inc delivery
just PM on here
Old Jul 11, 2007 | 03:12 PM
Mark 3D's Avatar
Mark 3D
Moderator
but this is £23 cheaper!!???
Old Jul 11, 2007 | 03:37 PM
RS500/364's Avatar
RS500/364
tHE COOSE IS YOURS what does you tunner say !!
Old Jul 11, 2007 | 04:15 PM
foreigneRS's Avatar
foreigneRS
Testing the future
if you want a simple answer, just buy silkolene pro s from oilman and be done with it
oilman
Trader Parts for Sale.
Sep 23, 2015 11:21 AM
