3 dr coilovers
Old Jul 10, 2007 | 09:10 PM
cosy trav's Avatar
cosy trav
Default 3 dr coilovers
im thinking of fitting coilovers to my 3 dr cosworth . im wondering if i have to strengthen the rear turrets as they dont seen to hold any weight due to the spring not being in the turret .
any advice will be much appreciated .
thanks trav .
Old Jul 11, 2007 | 05:35 AM
I've had coilovers on various sierras and never done it yet, and never had a problem.
Unless you are rallying it(?) I would say it is not needed.
Just be aware you may have to bash the area around the coilover where it is vertical on the back as some touch the body, some do, some don't .
Old Jul 11, 2007 | 08:34 AM
Ridgey's Avatar
Ridgey
No
Old Jul 11, 2007 | 04:11 PM
cossie604's Avatar
cossie604
As above...your ment to officialy but ive never had a problem with my 3dr.
Old Jul 11, 2007 | 04:35 PM
Niall.b's Avatar
Niall.b
my passenger side rear inner guard needed a little modding with a large hammer for clearance but other than that no probs (using ledas)
Old Jul 21, 2007 | 07:15 PM
Sonic Boom's Avatar
Sonic Boom
I have Gaz Coilovers fitted to my 3 Door with no problems and they went straight on no Hammer Modifications Needed
Rich,
Old Jul 21, 2007 | 07:33 PM
K.Goa's Avatar
K.Goa
A lot of people say you need strengthening, but so far I have not been able to locate ANYONE who know of a specific car that`s had a problem with strenght of the turrets using coilovers.
Old Jul 22, 2007 | 03:26 PM
cosy trav's Avatar
cosy trav
big thanks to everyone who replied
glad i dont have to strengthen the turrets now .
Old Jul 23, 2007 | 10:31 AM
AndyPen's Avatar
AndyPen
Mines had a lot of track and fast road use without any apparent hassle - it does have a brace fitted though. Cheap enough from what I can gather and doesn't get in the way too much - see pic mate
Old Jul 23, 2007 | 11:20 AM
And a rear strut brace which is a defintite must can be made from a length of sqaure tubing, it is what I did and just drill a hole in each end.
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
