Enclosed Throttle Bodies???
Old Jul 10, 2007 | 07:37 PM
GTechR's Avatar
GTechR
Default Enclosed Throttle Bodies???
Running a set of 45 Jenvies, they are currently on long ram pipes with no filters, I've been toying with boxing the bodies and then having a big cone filter, conected by hose or alloy pipe or a combination of the two?
I'm thinking that this method would reduce the heat soak? Especially I'f I get it coated with some sort of heat barrier? Locate the filter somewhere near the headlight so there is plenty of cold air feed.
Are there any downfalls to this? The only one I can think of is the airflow or should I say the distance it has to travel, as this is normally a forced induction setup.
Old Jul 10, 2007 | 07:41 PM
GTechR's Avatar
GTechR
Just another thought... Using a NACA Duct in the wing would I get enough air flow to vent it to an air filter sat next too the wing?
Old Jul 10, 2007 | 07:48 PM
nilrem's Avatar
nilrem
STOP!... Carry on
something like this?
http://cgi.ebay.co.uk/SBD-air-box-DC...QQcmdZViewItem
Old Jul 10, 2007 | 07:52 PM
GTechR's Avatar
GTechR
LOL... yeah pretty much
Old Jul 11, 2007 | 04:50 PM
GTechR's Avatar
GTechR
What about the second question???
Anyone?
Old Jul 11, 2007 | 06:06 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
any extra cold air in the direction of throttle bodies is a bonus so if you can manage a decent cold air supply then I can't see a problem with heat soak that your probably getting now.
Dan
Old Jul 11, 2007 | 06:13 PM
Tony Ryan's Avatar
Tony Ryan
Turn the head round , cant the motor over 30 degrees and run a long scoop into the bumper , lol .
[img][/img]
Old Jul 11, 2007 | 06:17 PM
JonnyBravo's Avatar
JonnyBravo
Tony, Have you got any vauxhall xe spares ?
Old Jul 11, 2007 | 06:20 PM
Tony Ryan's Avatar
Tony Ryan
In a word ...... nope , sorry . Works engine suppliers were swindon then speiss, these were leased so i dont ever see them .
Old Jul 11, 2007 | 06:57 PM
timturbo's Avatar
timturbo
i saw a cold feed made by pipercross which bolts straight on to jenvey throttle bodies so will have a direct cold feed if helps?
Old Jul 11, 2007 | 07:06 PM
nilrem's Avatar
nilrem
STOP!... Carry on
yeh i saw that aswell! couldnt find it though...
Old Jul 11, 2007 | 07:36 PM
GTechR's Avatar
GTechR
I'll keep my eye out for the pipercross one thanx... My main reason the fabrication is a mate who can do it in his Nightshift... If ya catch me drift
Old Jul 11, 2007 | 07:45 PM
JonnyBravo's Avatar
JonnyBravo
Bugger, only spares I have seen were with 2 cars that were where my car is now.
How much do the engines change hands for ? (when they do come up)
Old Jul 11, 2007 | 07:51 PM
OldDan's Avatar
OldDan
This is what I'm using
Old Jul 11, 2007 | 07:53 PM
GTechR's Avatar
GTechR
Right click... save
Cheers matey
Old Jul 11, 2007 | 07:55 PM
OldDan's Avatar
OldDan
Oh, and no need for an air filter on the side, it has a little foam part just before the end of the casing
Old Jul 11, 2007 | 07:57 PM
GTechR's Avatar
GTechR
Ahhhh thats interesting... what sorta money you lookin at mate? and more importantly where'd ya get it?
Old Jul 11, 2007 | 08:36 PM
OldDan's Avatar
OldDan
I got it through Shawspeed, BUT you can get them from Tweeks http://www.demon-tweeks.co.uk/produc...ode=P/CC6275LH
Reverie also do one, a carbon one
But that comes in at £300
http://www.reverie.ltd.uk/shop/produ...77b3&g2=8292c5
Old Jul 11, 2007 | 08:41 PM
GTechR's Avatar
GTechR
Cheers matey...
Think i'll give the carbon one a miss
Old Jul 11, 2007 | 08:44 PM
OldDan's Avatar
OldDan
I thought that too, bit expensive for me, bit posh too.
Old Jul 11, 2007 | 08:46 PM
darren.cudd's Avatar
darren.cudd
jenvy also do one of these to bolt straight on. you tend to get a little bit of restriction over using a foam filter but not much.
ring jenvy, or omex would probably have them in stock as well.
Old Jul 11, 2007 | 08:48 PM
GTechR's Avatar
GTechR
Old Jul 11, 2007 | 09:08 PM
OldDan's Avatar
OldDan
Just out of interest, what engine / car is it in? Your escort? what kind of power?
Old Jul 11, 2007 | 09:18 PM
GTechR's Avatar
GTechR
Dan, it's an I4 Maxi Spec RS2000 lump mate, it's going in my maxi rep (it's in the resto section) link in my sig
Old Jul 11, 2007 | 09:20 PM
OldDan's Avatar
OldDan
Just seen it! Sweet, will sound the nuts
Old Jul 12, 2007 | 03:25 PM
AustenW's Avatar
AustenW
http://boardroom.wscc.co.uk/cgi-bin/...ST;f=3;t=54077
Old Jul 12, 2007 | 08:27 PM
GTechR's Avatar
GTechR
Interesting read...
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
