how much brake fluid for cossie
Old Jul 10, 2007 | 09:00 AM
xr4x4rs's Avatar
xr4x4rs
Default how much brake fluid for cossie
need to get some brake fluid as my system was completely dismantled so have none in what so ever
how much brake fluid would i need to get and what
dot 4 or 5.1?
as dot 4 i can get in 4 litre tub but 5.1 is only in 1litre bottles
any ideas please or is it one of them where it could be anything due to bleeding the calipers etc
Old Jul 10, 2007 | 09:26 AM
nilrem's Avatar
nilrem
STOP!... Carry on
from past expierience (grabted not a cozzy but still relevent) you dont use that much fluid... so a 1 litre should be ok!
never used dot 5.1... so im unsure...
Old Jul 10, 2007 | 09:32 AM
he's going to need more than a litre if the whole system was drained off
Old Jul 10, 2007 | 09:42 AM
sabres74's Avatar
sabres74
Ford spec is SAM-6C9103-A (DOT4) or ESD-M6C57-A (Super DOT4)
Old Jul 10, 2007 | 11:17 AM
xr4x4rs's Avatar
xr4x4rs
well i got a 4litre tub of dot 4 as they only had 2 litres of 5.1
should be ok if it boils up ill change it later on but its on a road car so the brakes arnt going to be hammered that much
thanks lads
Old Jul 10, 2007 | 01:56 PM
When I did mine I used less than 1 litre.
I always NOW buy att he time I need it, I used to buy a gallon at a time but came time to use some more it had gone off, so that's why I don't amymore.
IainRS1700T
Sep 25, 2015 06:44 AM
wattie
Sep 16, 2015 11:34 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
