how th ehell do you refit and adjust gearchange rod on CVH
Old Jul 9, 2007 | 09:10 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default how th ehell do you refit and adjust gearchange rod on CVH
took mine off to change gearbox how do i know were to position it when i tighten it up so gearbox is nice and tight and in lign again?
Old Jul 9, 2007 | 09:17 PM
coswurv's Avatar
coswurv
put the gearbox in reverse with a screw driver under the car, get your mate to hold the gear stick in the reverse position then refit the rod and do the 13mm nut up job done.
Old Jul 9, 2007 | 09:56 PM
Roosie's Avatar
Roosie
how far on do you put the sleeve over to tighten it
Old Jul 9, 2007 | 09:59 PM
coswurv's Avatar
coswurv
just as long as you have someone holding the gearstick in the car in the reverse position and the box in reverse it will go on fine
Old Jul 9, 2007 | 10:02 PM
iansoutham's Avatar
iansoutham
OCD Victim
Or just put a bit of rod into the hole in the bottom of the lever when it is in 4th (I think it is) before undoing linkage. Stops the linkage moving when released. That is the proper way to do it.
Old Jul 9, 2007 | 10:07 PM
djmillsy's Avatar
djmillsy
Fife Radge
as above but i use second
Old Jul 10, 2007 | 12:51 PM
coswurv's Avatar
coswurv
proper way !! who decides what is the proper way ive been doing these for years and it works fine but everyone to theer own
Old Jul 10, 2007 | 12:57 PM
RANJ's Avatar
RANJ
because what ian says is pretty much correct and you wouldnt get this problem
Old Jul 10, 2007 | 01:23 PM
iansoutham's Avatar
iansoutham
OCD Victim
Ford do. That is why they put the hole there
Old Jul 12, 2007 | 01:47 PM
Roosie's Avatar
Roosie
ok right still having probs first of all ive got o figure out if i have a s1 or s2 box as the haynes say select Reverse for S1`s and 5th for S2?
ive tried both but just cant get it right first question
how far out does the rod in the gearbox have to come out before tightened the linkage?
Old Jul 12, 2007 | 07:30 PM
iansoutham's Avatar
iansoutham
OCD Victim
Have you got a S1 or an S2? The boxes are different between cars.
Assuming you have an S2.....
...looking @ the box from the rear of the car.
Turn the gearchange rod in the box left and then pull towards you. This will select 5th.
Basically, whatever you have to do to select the gear on the gearstick, do the exact opposite on the gearbox to get the same action.
Old Jul 12, 2007 | 08:32 PM
Chris69's Avatar
Chris69
i just locked it in 4th usinf the hole and gearstick, then pushed the gear selector rod forward while it is not at an angle, tighten all up and seems fine
Old Jul 12, 2007 | 09:30 PM
iansoutham's Avatar
iansoutham
OCD Victim
Exactly
mk3ste
Oct 17, 2021 10:09 AM
Fezman1
Oct 2, 2015 01:22 PM
little bram
Sep 27, 2015 07:45 AM
IainRS1700T
Sep 25, 2015 06:44 AM
