Cam question/advice
Old Jul 8, 2007 | 08:19 PM
The Sludge's Avatar
The Sludge
garibaldi
Default Cam question/advice
For me saph , a 4x4, i want to uprate my cams. I have heard a lot about Bd14 etc, but do i need to genuinely replace both, or can i get away with just replacing my exhaust one????????
Old Jul 8, 2007 | 08:27 PM
ECU Monitor Enthusiast
Dont touch the exhaust cam at all
If you uprate to BD14 you will need to pocket the pistons.
All depends on what power you ultimately want
Old Jul 8, 2007 | 08:29 PM
The Sludge's Avatar
The Sludge
garibaldi
looking for around 360 ish
why pocket the pistons??
Old Jul 8, 2007 | 08:31 PM
You will/can EASILY get 360 without touching the cams.
mechanic28's Avatar
mechanic28
wont need a bd14 cam for 360bhp maybe a set of bd10s then go up to light blue injectors have to pocket the pistons due to the extra lift i seem to remember?
I personally wouldnt touch the cams at all for that power as the benefits
will only be felt with head porting/live map etc...
BD14 cam has a higher lift which moves them very close to the piston
when the valve opens.
At high rpm there is a danger they can touch so the pistons are pocketed
to allow a better clearance.
Old Jul 8, 2007 | 08:32 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
Just go for the intake cam, NOT the exhaust cause it flows more then anough.
You CAN use the std pistons but they have to be ajusted wery precisely because the cams lift a bit more.
But it is advisable that you pocket the pistons
Old Jul 8, 2007 | 08:34 PM
The Sludge's Avatar
The Sludge
garibaldi
ahhh right ok.
Im running 300bhp despiye the 330 conversion that was done by previous owner, needs a tune me thinks etc, but i was thinking of T35 turbo upgrade, light blues, remap with the bd 14s...
Old Jul 8, 2007 | 08:36 PM
mechanic28's Avatar
mechanic28
T34 with a .48 housing with light blues and u should see around the 370 mark! with standard cams
Old Jul 8, 2007 | 08:37 PM
The Sludge's Avatar
The Sludge
garibaldi
That sounds a plan. Thanks fella
Old Jul 8, 2007 | 08:39 PM
mechanic28's Avatar
mechanic28
no probs fella
Old Jul 8, 2007 | 08:40 PM
dave cos4x4's Avatar
dave cos4x4
standard cams are good enough for that power Ian.
geting the urge for more power already.
Old Jul 8, 2007 | 08:45 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Mine has a little head porting and standard cams with light blue injectors and a T34.55 turbo.
It made 371bhp and 351lb/ft @ 25psi peak boost.
Steve.
Old Jul 8, 2007 | 08:46 PM
The Sludge's Avatar
The Sludge
garibaldi
LOL, dave yeh sumat like that. When i got her i thought it was quick as fook, now im bored
I always said id be happy, i wouldnt go mad etc, but its happening now
Steve.
Sounds good fella
Old Jul 8, 2007 | 08:50 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Steve.
Sounds good fella
Thanks
Was in the June issue of Fast Ford and won the dyno day
The car would make even more power if it had a better map and more boost.
Steve.
Old Jul 8, 2007 | 08:54 PM
dave cos4x4
Ian,
its all going to be money money money if you are getting that way already.
just get it all mapped/set up by a pro and it will be ok.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
