3-bar map sensors
can you/does anyone do 3-bar map sensors with a threaded end for the boost pipe to fit on,wanting to do all the little boost pipes done in dash 3.if not how would you guys do it.
cheeRS in advance paul
They all have a push on fitting only.
The reason for this is to make you use the correct pipe size.
This is because the sensor needs to be far enough away from the manifold
so it doesnt get heat soaked internally and the small bore pipe alllows fast
air pressure movement so the response time is quick.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
