Computer tech people
Old Jul 8, 2007 | 10:02 AM
Terry Tibbs's Avatar
Terry Tibbs
Default Computer tech people
Right, I've downloaded a .bin file which is a driver.
I cannot convert it to an .Iso to virtually mount it, I cannot burn it as it won't let me, even though I have a correct .cue file with it.
What the hell can I do?!
Any help is greatly appreciated.
Old Jul 8, 2007 | 10:03 AM
ProjectBobcat's Avatar
ProjectBobcat
what happens when you open the cue file?
Old Jul 8, 2007 | 10:04 AM
roybacer's Avatar
roybacer
Should do the trick
http://www.magiciso.com/tutorials/miso-whatsimage.htm
Old Jul 8, 2007 | 10:26 AM
Terry Tibbs
Says it isn't a CD image file, or its Unknown!
Starting to stress me out now, its a proper file, from the belkin website.
Old Jul 8, 2007 | 10:27 AM
roybacer's Avatar
roybacer
Can you explain what your trying to do and why ?
And the link to the belkin website ?
Old Jul 8, 2007 | 10:28 AM
Alex_86's Avatar
Alex_86
you could burn it with nero
you could mount itwith deamon tools
you could mount it or burn in with Alcohol 120%
Old Jul 8, 2007 | 10:30 AM
Terry Tibbs
Tried, tried, tried.
I'm trying to install a router so I don't have to use this pony wireless adapter thing. It keeps messing around going on and off and I'd rather have the Ethernet shoved in the back and the internet to be on all the time rather than when it suits the adapter.
BigMouthBillyBass's Avatar
BigMouthBillyBass
sounds like you've download a binary file, which is likely to be firmware for a router or something. If it's for a router you have to upload the bin file to the router using the web config through your browser.
what exactly are you trying to do?
Old Jul 8, 2007 | 10:31 AM
BigMouthBillyBass
you don't need drivers for an ethernet router mate, that file will be as i said above, updated firmware (the software and config that the router is running, stored on the chips)
Don't bother fucking about with firmware unless your having serious problems that an updated software build may fix. I've seen many people turn routers into doorstops through flashing firmware when they weren't quite sure what they were doing
Old Jul 8, 2007 | 10:32 AM
Alex_86's Avatar
Alex_86
give us a link then
and name of the router
Old Jul 8, 2007 | 10:46 AM
Terry Tibbs
So how do I make the router allow me to connect to it through the ethernet cable rather than the sodding wireless adapter thing then?
Old Jul 8, 2007 | 10:49 AM
BigMouthBillyBass
just plug it in. It'll give you an IP address and off you go
Old Jul 8, 2007 | 10:53 AM
DanRSturbo's Avatar
DanRSturbo
Exactly, just plug ethernet into one of the ports and job's done
mk3ste
Oct 17, 2021 10:09 AM
Rsmat
89
Oct 12, 2015 07:50 AM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
rsguy
44
Sep 29, 2015 03:29 PM
