How accurate is GPS speed ?
Old Jul 7, 2007 | 10:54 PM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Default How accurate is GPS speed ?
Borrowed my mates Road Angel Sat Nav and noticed the speed on the GPS wasn't reading what my car was saying.
Just wondering how accurate GPS speed is ?
Old Jul 7, 2007 | 11:04 PM
CharlieSaff's Avatar
CharlieSaff
I thought it was meant to be spot on!
Old Jul 7, 2007 | 11:28 PM
vikingboy's Avatar
vikingboy
AFAIK - its measured by doppler shift of the GPS signal so should be very accurate....99.9%?
Old Jul 7, 2007 | 11:30 PM
Rick's Avatar
Rick
VERY accurate mate. Much more than ur speedo.
Old Jul 8, 2007 | 01:53 AM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Its been commented on for years that speedos are inaccurate to around 10%.
Normally they're "ok" at around 50mph - but either side of that they tend to over-read.
Which is handy when you go through a GATSO and look at your speedo as you see it and your needle's sat just over 30
Old Jul 8, 2007 | 07:47 AM
RS500/364's Avatar
RS500/364
DRIVE YOUR CAR AT HALF SPEEDO
120 DRIVE 60
SEE WHAT THE GPS IS AND THEN SORT YOUR SPEEDO SO IT IS RIGHT
Old Jul 8, 2007 | 07:52 AM
Fiecos Dan's Avatar
Fiecos Dan
my 'Snooper' = 135mph, and on PF timing gear i was doing 133mpg.
My brothers 'Angel' = more accurate.
Old Jul 8, 2007 | 08:00 AM
St3V3_C's Avatar
St3V3_C
GPS is spot on, but there is a delay if accelerating. You need to be at the same speed for a few seconds and then look at it.
Old Jul 8, 2007 | 08:22 AM
Fiecos Dan's Avatar
Fiecos Dan
i was for 5 seconds.
but that will only work if the snooper/angel was under reading, not over reading.
Old Jul 8, 2007 | 10:27 AM
dojj's Avatar
dojj
Resident Wrestling Legend
ours measures speed to 5 decimal places
but it's on the tracker
Old Jul 8, 2007 | 10:43 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Datron timing gear was 2mph faster than GPS monitor in car, my Stack speedo gave the same speed as Datron.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Becka674
11
Oct 8, 2015 03:11 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
Chopshop85
Sep 18, 2015 06:13 AM
