factory ignition marking?
Old Jul 7, 2007 | 07:04 PM
Dragsteer's Avatar
Dragsteer
Default factory ignition marking?
hello
Is this on picture factory setting for ignition 12 degrees? I have stock engine- boost, cam ... and want to know can I set ignition by this mark?
Old Jul 7, 2007 | 09:24 PM
Rick's Avatar
Rick
there is no mark - u do it with a timing light.
Old Jul 8, 2007 | 07:35 AM
Fiecos Dan's Avatar
Fiecos Dan
As above, that mark means nothing, as the dissy/cam might of been changed since someone made that mark, or even a head skim, which will all put that mark out, (even if it was correct at the time??)
Use a timing light, and the marks on the lower cam belt cover, and TDC mark on the lower pulley.
you will need to remove and block the ecu vacum/bost feed, and set the rpm to around 900 rpm for this test.
Even better, is to set you timing up using det can's. Advance to det, and retard 2-3 degrees. Then check static idle timing as reference.
Old Jul 8, 2007 | 10:22 AM
Dragsteer's Avatar
Dragsteer
ok. Thanks
I dont know about det cans so I will set it with strobe.
Mark RS
Mar 5, 2021 06:08 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
