cars not holding boost ? how do i know if its the actuator ?
Old Jul 7, 2007 | 02:20 PM
woodz77's Avatar
woodz77
Default cars not holding boost ? how do i know if its the actuator ?
as title really . flys to 20 psi then leave it in gear and it falls to 12 ??
i dont know alot but i would have thought its the actuator but is there away of telling ??
its a S2 by the way
Old Jul 7, 2007 | 02:31 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
could be...............but what about a leak somewhere.???.........u need to pressure test..............
Old Jul 7, 2007 | 03:27 PM
woodz77's Avatar
woodz77
pressure test ?? sorry to seem thick , but what do you mean ? pressure test the engine ?
Old Jul 7, 2007 | 03:57 PM
Fiecos Dan's Avatar
Fiecos Dan
Pressure test the boost system.
Take it to a garage or tuner that can do this.
Easy if know how and got the equipement.
Old Jul 7, 2007 | 04:05 PM
woodz77's Avatar
woodz77
got you
looks like a trip to SCC in the week
Old Jul 7, 2007 | 04:12 PM
4x4's Avatar
4x4
if it was a weak spring in the actuator wouldn't it not even boost to 20psi at all
Old Jul 7, 2007 | 04:40 PM
pete mcrash
u can still test ur actuator with a foot pump..........
put the pump on here and inflaite..............if it holds pressure its good....
Old Jul 7, 2007 | 05:02 PM
woodz77's Avatar
woodz77
blimey . i never knew that . . im going out in a while to have a go
Old Jul 7, 2007 | 06:29 PM
Fiecos Dan's Avatar
Fiecos Dan
if its a -31, it should move around 4-6mm @ 10 psi.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
jay030787
Aug 17, 2015 06:16 PM
no1trancefan
Ford Focus ST
Aug 7, 2015 09:21 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
