ECU swap...
Old Jul 6, 2007 | 06:01 PM
EscortMatt's Avatar
EscortMatt
Default ECU swap...
Hi all, i've just acquired a chipped ECU for my S2, i know that once fitted i will have to get the car set up, but in terms of fitting is it just as simple as unplug the standard ECU and plug in the chipped one...?? Also the front of the chipped ECU doesn't have the coloured squares on it are they all interchangeable...??
Help much appreciated...
Old Jul 6, 2007 | 06:51 PM
fast_ford_uk's Avatar
fast_ford_uk
yes just unplug the ecu, undo the 10mm nuts fit new ecu. tighten nuts and refit multiplug
Old Jul 7, 2007 | 11:28 PM
Rick's Avatar
Rick
Hi mate. Yes, it is a simple swap - providing your car has a knock sensor - which if it's a later S2 it will have. Later ECU's HAVE to have a knock sensor. It may be that the new one needs a knock sensor, and urs doesnt - but i doubt it...
A knock sensoe is a green plug on the right hand side of the inlet.
Rick.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
