First pictures of new engine/turbo .
Old Jul 6, 2007 | 04:55 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Default First pictures of new engine/turbo .
The engine is almost complete & today Mark was sorting out details to allow swift change over of 2 turbos , 2 manifolds, 2 inlets & 4/8 injectors.
The Dyno is now booked for 2 maybe 3 days so we can really find out what works best with what.
Old Jul 6, 2007 | 04:56 PM
dave cos4x4's Avatar
dave cos4x4
just a cossie engine with a bigger turbo.
Old Jul 6, 2007 | 04:57 PM
GARETH T's Avatar
GARETH T
keep us informed rod
Old Jul 6, 2007 | 05:27 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
has your car always run a 2wd head rod? looks mice btw
Old Jul 6, 2007 | 05:29 PM
aduz's Avatar
aduz
should go well in a straight line
Old Jul 6, 2007 | 05:30 PM
Mark Shead's Avatar
Mark Shead
Yes it has.
Mark
Old Jul 6, 2007 | 06:03 PM
glancy2081's Avatar
glancy2081
two different manifolds
Old Jul 6, 2007 | 06:08 PM
Mr RS500's Avatar
Mr RS500
Good luck to you and Mark
Old Jul 6, 2007 | 06:09 PM
Mark Shead's Avatar
Mark Shead
Yes part of the testing is 2 diff turbo's with a total of 4 combinations/2 exhaust manifolds/2 inlet manifolds, 4 1200cc injectors and 8 750cc injectors the hope is none of the manifolds are better because the inlet is around 3k and the exhaust manifold is the same ,
Some of the testing will be keeped secret and we will prob only let out the max figures as the testing of all these parts is costly and I belive I should be the only one to benafit from it .
Mark
Old Jul 6, 2007 | 06:12 PM
gus's Avatar
gus
who did you get to coat your manifold?
Old Jul 6, 2007 | 06:16 PM
MAD matt-sab's Avatar
MAD matt-sab
awesome pics and work as ever guys !!!!!!!!!!!!
BEST of luck mark/rod !
Old Jul 6, 2007 | 06:19 PM
Mark Shead's Avatar
Mark Shead
Zircoat if I spelt it right.
Mark
Old Jul 6, 2007 | 06:20 PM
Mark Shead's Avatar
Mark Shead
I will also be testing upto 4 diff combinations of camsafts.
Mark
Old Jul 6, 2007 | 06:25 PM
Turbo Zetec
Engine Machinist
is there a reason for choosing the 2wd head mark? i was under the impression it was prone to cracking because of the chamber design? not a dig or anything, just curious as i was going to sell my 2wd head for a 4x4, but if it's okay for big power, i may aswell keep it!
glancy2081's Avatar
glancy2081
Mark
thanks mark thought a was seeing things at first are these tests just to achieve max power or to see which has the longest power band
Old Jul 6, 2007 | 06:30 PM
Mark Shead's Avatar
Mark Shead
I have used both types of head and found no diff in power or reliablity.
Mark
Old Jul 6, 2007 | 06:33 PM
JonnyBravo's Avatar
JonnyBravo
Don't suppose this car does 200mph does it ?
Obviously won't hear the figures which is fair enough but you are certainly going to town on what works best.
Fair play and good luck
Old Jul 6, 2007 | 06:34 PM
JonnyBravo's Avatar
JonnyBravo
Mark
Now that is interesting, what do you know about cracked 200 blocks Mark ?
Turbo Zetec
Engine Machinist
awesome, cheers mark
Old Jul 6, 2007 | 06:35 PM
Mark Shead's Avatar
Mark Shead
Mark
Both manifolds are split pulse as is the exhaust housings on the turbo's, The first black manifold works well but the second white one is a very new desgin which I think is better so its the best opportunity to test them.
Mark
Old Jul 6, 2007 | 06:38 PM
Mark Shead's Avatar
Mark Shead
Mark
I know that the later blocks have had core shift and this has made them weak over 92mm or very high power on smaller bores,
My contact at Cosworth says they are looking to make new blocks/head but the time scale is unsure but I would guess over a year.
Mark
Old Jul 6, 2007 | 06:44 PM
JonnyBravo's Avatar
JonnyBravo
Thanks Mark
Old Jul 6, 2007 | 06:59 PM
boXXer's Avatar
boXXer
GASH!
Looking good buys
BTW Mark: Thanks for helping me with my car that night i phoned you about my yellow injector being stuck.
Old Jul 6, 2007 | 08:32 PM
GARETH T's Avatar
GARETH T
i would love to help you do the testing
Old Jul 6, 2007 | 08:46 PM
Rick's Avatar
Rick
me too lol
Old Jul 6, 2007 | 08:54 PM
smitsturbo's Avatar
smitsturbo
ok so say all goes well & the right parts are picked when can we be expecting this all bolted up and running again mate
Old Jul 6, 2007 | 08:56 PM
Mark Shead's Avatar
Mark Shead
Before TOTB
Mark
Old Jul 6, 2007 | 08:59 PM
smitsturbo's Avatar
smitsturbo
nice, i hope to be there as a witness
Old Jul 6, 2007 | 09:06 PM
Dingy's Avatar
Dingy
Big blower on what looks to be a standard engine LOL...
Dumped's engine pics are interesting this is more of 200mph boredom
Old Jul 6, 2007 | 09:15 PM
Kevin Atkins's Avatar
Kevin Atkins
I think Mark may surprise a few people on the handling circuit at TOTB, Rod's car ain't slow round corners.
Kev
Old Jul 6, 2007 | 09:20 PM
ECU Monitor Enthusiast
Rod,Mark,
cant wait to to the results.
Dingy,
You are indeed a cock
Dingy's Avatar
Dingy
Kev
its a saff ffs
Old Jul 6, 2007 | 09:21 PM
Dingy's Avatar
Dingy
Originally Posted by 68332
Rod,Mark,
Dingy,
yeah and you don't answer anything but abuse....FACTAMUNDO....
Old Jul 6, 2007 | 09:23 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
215 hopefully dingy & with a 10s quarter to boot, all very boring .
Old Jul 6, 2007 | 09:25 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Wow - looking good.
Had a quick chat with Mark the morning before Time Attack Silverstone and he said things were moving on with yours
Which turbo is that in the pics? GT4088? GT4094? GT42R variant?
Looking forward to the dyno figures all the same - best of luck
Dingy's Avatar
Dingy
each to there own mate, terry's mk 2 does 10's fast car, faster than yours and doesn;t interest me.
Good luck with it.
Old Jul 6, 2007 | 09:33 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Maybe I'm a tool too but if I bolted a big turbo on a Godfrey design manifold on any engine in my workshop then it would look the same... for once in Dingy's life he is right!!
Having said that Good luck Rod, hope it works for you
Old Jul 6, 2007 | 09:40 PM
Mark Shead's Avatar
Mark Shead
Wrong the manifold was made and desgined by PD and this is not the same as the one there made for JG several years ago, and this one was made/adjusted to what I wanted by PD ,
One day we may see yours run at full power but I do belive its been 9 months running on and off seems to me you are scared to run it at full power, Do you think the head will come off
Mark
