Drilling Near Miss..........
Old Jul 6, 2007 | 03:24 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Default Drilling Near Miss..........
Got Virgin round at mine at the mo installing Digital telly & the guy had to drill a hole through from the lounge to my bedroom to set the box setup (couldnt do it on my plasma at the mo....long story - Denon amp fucked up the other day & it controls my signals to the plasma!)...anyway
How foooookin close is that to the plug socket!!!!!
Bet he couldnt do that again if he tried.......we didnt realise the extension wasnt level with rest of the house - and he'd drilled about 6" in from the corner of the other side too to miss it on purpose!!!!
He nearly left mine with a hell of a shock & nice hairdo to remember the job by!!!!
Old Jul 6, 2007 | 03:26 PM
andyt's Avatar
andyt
Old Jul 6, 2007 | 03:27 PM
Fil's Avatar
Fil
ELASTIC BAND
errr.............coyboy alert
Old Jul 6, 2007 | 03:28 PM
Dan Cossie's Avatar
Dan Cossie
shit
BlueXR2's Avatar
BlueXR2
should have drilled it from the plug side?
Old Jul 6, 2007 | 03:38 PM
Lee_R21Turbo
....if he'd of done that he'd probably of ended up outside!!!
Old Jul 6, 2007 | 03:46 PM
dave cos4x4's Avatar
dave cos4x4
close Lee.
Old Jul 6, 2007 | 04:35 PM
Old Jul 6, 2007 | 04:37 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
shocking
Old Jul 6, 2007 | 04:42 PM
nilrem's Avatar
nilrem
STOP!... Carry on
am i the only one that cannot see a hole?
Old Jul 6, 2007 | 04:47 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
how about the fucking huge drill poking through the wall?
Old Jul 6, 2007 | 04:48 PM
steves24V's's Avatar
steves24V's
NO your not!!! is it the small mark above the left hand plug in the socket its self ???????????????????????????????
Old Jul 6, 2007 | 04:50 PM
nilrem's Avatar
nilrem
STOP!... Carry on
ah right! yeh thats close then...
Old Jul 6, 2007 | 04:51 PM
Fil's Avatar
Fil
ELASTIC BAND
You's two serious??
if so
Old Jul 6, 2007 | 04:52 PM
RS_Cosworth330's Avatar
RS_Cosworth330
Look underneath the white plug!!!
Old Jul 6, 2007 | 04:53 PM
indycos's Avatar
indycos
helooooo!!!
theres a massive fucking drill coming out of the skirting board thingy
Old Jul 6, 2007 | 04:55 PM
DaveZS's Avatar
DaveZS
Better use my strong hand
You's two serious??
if so
Wouldn't let them start drilling holes in my walls
GARETH T's Avatar
GARETH T
bloody lucky,,, if he would of been a few inchs higher he would of drilled through that retro double socket outlet
Old Jul 6, 2007 | 04:57 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Take a looky inside the red circle
Old Jul 6, 2007 | 04:58 PM
Rab's Avatar
Rab
Fucking superstar........
Can you lot not see the drill bit sticking out from under the white plug?
Old Jul 6, 2007 | 05:00 PM
Lee_R21Turbo
Some of you are right BLIND fuckers.......dont suppose you are mates of the installer are you!!!???
Gareth.....you takin the piss outta my plug socket???
Old Jul 6, 2007 | 05:17 PM
steves24V's
well you didn't say the drill was still in the hole,
i was looking for a hole not a drill piece, saw that but thought it was a wire or something coming out of the plug socket and going behind the skirting board,
some one else must of thought the same thing, or did i just spend too long down the pub after work
Old Jul 6, 2007 | 05:21 PM
Brian's Avatar
Brian
Thats close
Brian
Old Jul 6, 2007 | 05:24 PM
djmillsy's Avatar
djmillsy
Fife Radge
Old Jul 6, 2007 | 05:28 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Fucking hell that was close!!
LOL@blind fuckers too
Old Jul 6, 2007 | 05:49 PM
Jay,'s Avatar
Jay,
Sponsor
Old Jul 6, 2007 | 07:05 PM
Fast Guy's Avatar
Fast Guy
My mums house is like that. I drilled a hole in the corner of the lounge to pass a cable into the hall, when I looked into the hall there was no hole. The walls were obviously so far out that it must have gone into the cavity near the outside wall somewhere. I ended up drilling about another foot over for it just to come out about 3" from the wall. Houses just aren't built very square sometimes.
Old Jul 6, 2007 | 09:39 PM
GTechR's Avatar
GTechR
I used to install systems, and I cant understand why the fuk he's drilled from the outside inwards.
We allways drilled from inside the house outwards...
That said... Once I was up in a gable end of a house fitting a dish, and it had been stone clad then painted. All I remember is a loud bang and a big flash, the next thing I knew I was hanging upside down from the ladder, a hole in the wall the size of a dart board and the entire village with no power... Fukkin stupid place to put the mains cable to the house
It had also completley melted the drill bit
Old Jul 6, 2007 | 09:45 PM
Mark_w's Avatar
Mark_w
if you drill from inside to the out,dont you take a big chunk of brickwork when it breaks through???
regards mark
Old Jul 6, 2007 | 09:46 PM
mechanic28's Avatar
mechanic28
nice
Old Jul 6, 2007 | 09:47 PM
Lee Reynolds's Avatar
Lee Reynolds
lmfao
Bet that sockets worth a few quid...antique
And DUMP the triple adaptor
Old Jul 6, 2007 | 09:48 PM
Lee Reynolds
regards mark
yes normally...BASTARDS
Old Jul 6, 2007 | 09:50 PM
GTechR's Avatar
GTechR
regards mark
95% of the time no, if your good you can tell from the tone off the drill bit as your about to break thru, you simply decrease the speed off the drill and the pressure, and bobs ya unc.
Old Jul 6, 2007 | 09:51 PM
Lee Reynolds
regards mark
I wish youd come and do them for us then Never seen a sparkie do a good hole yit
Old Jul 6, 2007 | 09:53 PM
Lee_R21Turbo
That was from the inside....IN!!! LOL! Lounge --> Bedroom!!!
Lee R - Bid me up on it....basically tight fisted landlord not wanting to spend any money!!!!
Triple adaptor...you really dont want to see my front room then...I have 1 sole lonely plug socket with a triple adaptor on feeding the following...
1 - computer side - with 2x 6 way extentions on
2 - tv side - 2 x 4 way extentions on
3 - printer/fax/scanner
Lambchop's Avatar
Lambchop
PF Idiot Sniper
aye but behind that socket is the bedroom! NOT outside
Old Jul 6, 2007 | 09:55 PM
GTechR's Avatar
GTechR
regards mark
Gis a Job then...
Lee Reynolds
omg
Old Jul 6, 2007 | 09:56 PM
GTechR's Avatar
GTechR
yeah yeah... I didn't realise that
Old Jul 6, 2007 | 09:57 PM
Lee_R21Turbo
You've almost got a good memory mate...otherway round!!!
Behind that is the lounge!!! LOL!
