Engine problem, anyone give some ideas?
Old Jul 6, 2007 | 09:09 AM
ballin's Avatar
ballin
Default Engine problem, anyone give some ideas?
Its a Renault Megane (2000 so old style), and car is abroad at the moment so I'm trying to help over the phone!
basically, quite frequently the revs will raise at idle to about 1100rpm (from 700ish) and run very lumpy.
Also when driving, often the car loses a lot of power, again feels lumpy and doesnt really accelerate at all, then all of a sudden it will cure and lurch forward.
happens when engine is hot or cold, but seems a bit better when warmer.
To me this sounds like its running on 3?
Are there any other quick things people can suggest to check? Im getting more details later but for now thats the obvious cause?
No engine management light on either if that helps
Cheers all
Old Jul 6, 2007 | 09:15 AM
gingeRS's Avatar
gingeRS
sounds like it could be a fuelling fault. (if its not a spark fault - ie running on 3)
check the lambda sensor as these often fail
Old Jul 6, 2007 | 09:23 AM
ballin's Avatar
ballin
cheers will try and get the message over, im hoping its not a sensor fault and its something easy to fix up temporary!
Old Jul 6, 2007 | 09:57 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Could also be EGR or a coil (if runnin seperate coils) as they're reknown for them breaking down ! ! !
Good luck !
Jb
Old Jul 6, 2007 | 10:34 AM
ballin's Avatar
ballin
Cheers Jb, just been trawling the renault forums, you're quite right, looks like its most likely coil dying, hopefully it wont take out the cat before it gets back to the UK
Old Jul 6, 2007 | 10:38 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
they run AFMs? sounds like fucked/disconnected AFM too.
Old Jul 6, 2007 | 11:15 AM
DANNY-B's Avatar
DANNY-B
Good luck !
Jb
I'd agree with this guy, they're well known for it.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
taylora1409
Aug 12, 2015 12:06 PM
mattman1234
24
Aug 1, 2015 11:46 AM
