Home Entertainment/Wiring Folks....
Just moved into a new place.
In the living room there is a master tv/phone point. It's a white box with a TV antenna connection, DAB radio connection, Sky Satellite Connection, Telephone, but also one called RETURN.
Does anyone know what this does?
Both the bedrooms have coax TV points in them, and I'm hoping I can run the coax output of the Sky box into the return, for it to feed through to the bedrooms, via the existing cable?
Any ideas?
Any ideas?
the sky works of a scart lead i tryed running a coax lead of my skybox before and couldn,t get it to work. i would like to know myself i done it through my video player put the skart in the back of it and used the tv out
the one marked return will probably go to a dis box in the loft that runs all the other tv points.
So you go through your sky box etc, then you split the signal between your main tv and the return. this then gives you sky on all tv points. Some people will send the signal to the loft then back down to the main tv and other points so its not splitting it before the signal booster.
edit, just read the rest of your post and think you already have it sussed
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
