Oil pump.....
Old Jul 4, 2007 | 09:05 PM
warleydaddy's Avatar
warleydaddy
Default Oil pump.....
Whats the differance between a 2wd oil pump,and say a uprated pinto pump???
Pete...
Old Jul 4, 2007 | 09:08 PM
CharlieSaff's Avatar
CharlieSaff
Stronger spring or std spring with a 5mm or such size packing plate to make it higher pressure
Old Jul 4, 2007 | 09:10 PM
warleydaddy
So could you fit a 2wd pump in to a pinto (its out of a high reving stock car)??
Pete...
Old Jul 4, 2007 | 09:25 PM
JamesH's Avatar
JamesH
AFAIK they're the same
I know people woh've built cossie engines and used pinto lumps with the mod to the spring
Old Jul 4, 2007 | 09:54 PM
abdr500's Avatar
abdr500
the pinto pump use a different top plate on the pump so if you plane on using one then you have to use your cosworth 2wd top plate and you will be fine
Old Jul 4, 2007 | 10:02 PM
warleydaddy
Well its a pinto engine....
Got stupid oil pressure problems,so thinking of putting a 2wd pump in,hence asking the question...
Think id be better off just putting a straight replacement in,or have a go with a 2wd 1??
Pete...
Old Jul 4, 2007 | 10:22 PM
abdr500's Avatar
abdr500
warleydaddy
if you have a oilpump problem then replace the oil pump but if your problem i engine related then no pump will fix it
Old Jul 5, 2007 | 07:00 AM
CharlieSaff
If it's a pinto one then just buy a pinto pump you can get them for £25-£30
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
