URGENT HELP
Old Jul 4, 2007 | 08:20 AM
NoNoCos's Avatar
NoNoCos
Default URGENT HELP
Hi !
There is modifications or make an adjustement on cylinder head for fitting a Kent valve springs or it's just disassembly and reassembly ?
The kit number is : VSK 32 P
It's for fit BD14 inlet and BD10 exhaust.
Regards.
Old Jul 4, 2007 | 08:23 AM
sygjim's Avatar
sygjim
not sure
some, machining the springs seats...... but with this kit, i don't know....
Old Jul 4, 2007 | 09:17 AM
So long as the springs have 34mm installed height they will be ok.
Old Jul 4, 2007 | 12:19 PM
NoNoCos's Avatar
NoNoCos
So, there is something i don't understand, when i measure this 34mm and in relation with what ?
Regards
Old Jul 4, 2007 | 04:05 PM
You measure from the VALVE SEAT area on the head to the UNDERSIDE of the SPRING retainer, 34 MM IS OPTIMAL BUT 1/2MM EITHER WAY IS OK TOO.
Just do a dummy fit with a weak spring, out of anything to measure.
DaveN
13
Jan 9, 2005 06:19 PM
R4N SS
Jan 1, 2005 12:17 AM
Walshy
May 14, 2004 01:34 PM
