Would like to improve my 1.8 zetec escort.....performance
Old Jul 3, 2007 | 02:05 PM
D7AKE's Avatar
D7AKE
Default Would like to improve my 1.8 zetec escort.....performance
Any help apreciated, got to make my runaround abit quicker
What do I need?
cams?
head?
chip?
Throttlebody?
ecu?
Trying to do it on the cheap...
Si
Old Jul 3, 2007 | 02:47 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
turbo?
i have a 2.0l zetec inlet can on egay at the mo.
buy that and ill bring it combe lol
also got an FSE power boost valve fuel reg, but doubt that will do anything on its own.
Old Jul 3, 2007 | 03:00 PM
D7AKE's Avatar
D7AKE
99p
Old Jul 3, 2007 | 03:01 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
thats what its on at the mo lol
Old Jul 3, 2007 | 03:39 PM
foreigneRS's Avatar
foreigneRS
Testing the future
save your money and put it towards a car with a better engine in the first place. there's a reason that the rs2000 was made.
ever heard the saying "you can't polish a turd"?
harsh, but ultimately true. i wish i'd saved my money and not wasted it on shit little engines when the 'improvements' that you do make very little difference in the scheme of things
Old Jul 3, 2007 | 11:31 PM
neilm's Avatar
neilm
Stick it on a set of Weber 40 carbs and an after market ecu like OMEX or Weber Alpha and expect to see around the 155bhp mark.
You could even use a MegaJolt ECU, See AF Racing for further detials.
either way its a very cheap 35-40bhp and none of the fannying about and aggro you get with turbos.
Alternatively stick an ST170 motor in there on after market management and see around the 170-180bhp mark
Old Jul 4, 2007 | 07:33 AM
foreigneRS's Avatar
foreigneRS
Testing the future
neilm do you mean a set of throttle bodies with fuel injection and an aftermarket ecu, or actually carburettors and just an ecu for ignition?
i would not go near carbs in this day and age
Old Jul 4, 2007 | 07:57 AM
D19 STE's Avatar
D19 STE
Wish I listened to this advice and got my RS2000 earlier before spending Ł****s on getting my 1.8si upto 150bhp
I sold it as at the end of the day it was only a 5 door Si but it was quicker than all the other 5 door escorts in my area
Old Jul 4, 2007 | 08:10 AM
It's Czech Mate's Avatar
It's Czech Mate
Old Jul 4, 2007 | 12:26 PM
D7AKE's Avatar
D7AKE
tis a very good point but mine is an Estate and I need an estate...........mmmmm sound familiar?
Old Jul 4, 2007 | 12:30 PM
Garage19's Avatar
Garage19
Best way to tune a 1.8 is replace it with a 2ltr for starters!
Old Jul 4, 2007 | 03:30 PM
foreigneRS's Avatar
foreigneRS
Testing the future
as said then, stick a 2 litre (or better still rs2000) lump in your estate
Old Jul 4, 2007 | 05:23 PM
gup's Avatar
gup
how about to convert the car to an rs1800 for a bit more poke
ie
cams
throttle body
inlet
ecu
and so on fella
at least it will be an easy conversion
Old Jul 4, 2007 | 10:22 PM
neilm's Avatar
neilm
Not mate.. I mean buy a set of 40's off e-bay for under Ł200... stick a MegaJolt on it... and fuel pressure regulator to drop the fuel pressure right down and bob is your firkin...
A very cheap 40bhp.
Old Jul 8, 2007 | 07:51 PM
D7AKE's Avatar
D7AKE
ie
cams
throttle body
inlet
ecu
and so on fella
this is what Iam thinking of doing so I just need to know exactly what bits I need to get me started.....
Otherwise I will buy an RS2000 engine, if I do what else will I need for the conversion?
Thanks for all replys
Old Jul 8, 2007 | 07:57 PM
rssteve's Avatar
rssteve
surely the escos was built to better the rs200 tho so why bother with that turd
Old Jul 8, 2007 | 08:29 PM
mechanic28's Avatar
mechanic28
i would not spend to much money on it fella maybe just a stainless steel exhaust and induction kit and thats it!as it gets quite expensive after that with very little gains!!!
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
