Valve Springs
Hi !
There is modifications or make an adjustement on cylinder head for fitting a Kent valve springs or it's just disassembly and reassembly ?
The kit number is : VSK 32 P
Regards.
Regards.
Hi,
To be sure, you fit one valve with your new kent springs and your camshaft.
You check at maximum lift of your camshaft if you have 1.27 mm. or more before coil bind.
(50 thou)
If you "bump", head machining is necessary !!!
Regards
Claude
(50 thou)
Regards
Claude
SMILER258
Sep 28, 2015 09:04 AM
