cosworth brakes no good
Old Jul 3, 2007 | 10:24 AM
Gregor's Avatar
Gregor
Default cosworth brakes no good
I've fitted 4pot 2wd calliper and 286 disks @ the front and sierra xr4 256 mm disks and callipers @ the rear.
rear works verry well but the front doesn't seem to brake verry wel so they say when it was for MOT this morning.
Anyone else got this problem?
Could the master brake cilinder be to smal, and what can i fit instead.. cosworth or something else?
thanks..
Old Jul 3, 2007 | 10:31 AM
cozmeister's Avatar
cozmeister
More boost Igor!
If the pistons in the calipers aren't siezed, make sure you haven't got an air lock, or leaking servo.
Old Jul 3, 2007 | 03:09 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
brake bias ?
Old Jul 3, 2007 | 03:50 PM
Fiecos Dan's Avatar
Fiecos Dan
a mate fitted a full 2wd cossie front set up on his RST, and they were crap, so he replaced them with wilwoods.
Old Jul 3, 2007 | 08:38 PM
Gregor's Avatar
Gregor
Originally Posted by UnseenMenace
brake bias ?
haven't got it on there..... would an aftermarket one be sufficient to get less brakingpower on the rear and more at the front...?
in other words, is the brake cilinder up to the job?
Old Jul 3, 2007 | 08:39 PM
Gregor's Avatar
Gregor
Will check it all again but looked fine to me
Old Jul 3, 2007 | 08:40 PM
Gregor's Avatar
Gregor
i didn't want to hear that...
Fiecos Dan's Avatar
Fiecos Dan
brake bias ?
Yep
Old Jul 3, 2007 | 08:42 PM
Gregor's Avatar
Gregor
brake bias ?
Yep
Ok but wil the brake cilinder be up to the job then ?
Old Jul 3, 2007 | 08:46 PM
Fiecos Dan's Avatar
Fiecos Dan
i dont know, as never tried.
But you will need a brake bia for the rears, no matter what servo you fit.
Old Jul 3, 2007 | 08:56 PM
Gregor's Avatar
Gregor
ok, understand that... wil order one and see how it goes.. thnx
original
Apr 28, 2026 05:20 PM
markk
Dec 2, 2021 06:59 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
