does this spec sound anygood/ok to you
Old Jul 3, 2007 | 08:32 AM
fast_ford_uk's Avatar
fast_ford_uk
Default does this spec sound anygood/ok to you
2.1 Zetec Turbo Engine - 8.2:1 Compression Ratio - 15-18psi boost
Forged Vauxhall XE Pistons
Modified Con Rods to take the above
Focus Tripple Layer Steel Head Gasket
0.5mm Ally Shim bonded to head
ARP Rod Bolts
All new Rings, Seals, Bearings
Front Breather blocked, two fitted on the rear
Breather oil return fitted to rear of sump, and turbo oil return on the front
New water pump
The Block was bored out to take the pistons, and crank polished as it did not need a grind
Modified cam cover giving second breather, powdercoated black
Fully Reconditioned head, drilled and tapped to take t3 manifold
T3 & Manifold included,
Also ;a 4 paddle, megasquirt1 v3 board ,innovate lc1wideband lambda sensor kit, 370cc side fed injectors, Powder Coated Efi Inlet Manifold, Breather Pot,
Old Jul 3, 2007 | 09:59 AM
Fiecos Dan's Avatar
Fiecos Dan
Spec for what? and how much?
as all seems good, but ott if you want 170 bhp, and not worth it if £7k.
Old Jul 3, 2007 | 07:33 PM
fast_ford_uk
to go into an rst s2. i can get it all for £1500 what bhp do you recon?
Old Jul 3, 2007 | 07:39 PM
Fiecos Dan's Avatar
Fiecos Dan
std head? what spec turbo?
i dont know much about zetec turbo's but guess around 300+ bhp with correct turbo.
Old Jul 3, 2007 | 07:56 PM
fast_ford_uk
yea standerd zetec head. and a garrett t3 turbo at the min, running around 15 psi.
Old Jul 3, 2007 | 08:39 PM
Fiecos Dan's Avatar
Fiecos Dan
std rst t3 turbo?
if so, about 200-220 bhp
Old Jul 3, 2007 | 08:52 PM
fast_ford_uk
yes at present until i earn some more money for an upgrade
Old Jul 3, 2007 | 09:24 PM
gee686's Avatar
gee686
which xe pistons are you using. i am not 100% but wen i was looking to do the zt route i was advised to use the calibra turbo pistons rather than the n/a ones. where as the n/a ones are best for zvh. ahmed bayjoo told me this. dont know if it helps.
Old Jul 3, 2007 | 09:26 PM
fast_ford_uk
alrite cherz, ill have to ask as im not sure
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fudgey
21
Sep 30, 2015 06:19 PM
