Low Comp Pistons.........
Old Jul 2, 2007 | 08:54 PM
bigpower's Avatar
bigpower
Default Low Comp Pistons.........
Hi All,
Wheres the best / cheapest place to get low comp or pocketed pistons?
Thanks
Old Jul 2, 2007 | 08:55 PM
rapidcossie's Avatar
rapidcossie
Cheapest doesnt = best IMO
Buy the most expensive you can afford.
Old Jul 2, 2007 | 09:05 PM
bigpower's Avatar
bigpower
Most expensive doesnt always mean best either
What makes are people running and what style piston for around 400BHP
Just after a good deal and what people recommend
smitsturbo's Avatar
smitsturbo
america
Old Jul 2, 2007 | 09:09 PM
rapidcossie
Cossie racing ones will be cool for 400 bhp and they come next day.
Old Jul 2, 2007 | 09:10 PM
bigpower's Avatar
bigpower
Any links?
Old Jul 2, 2007 | 09:13 PM
rapidcossie
Sure they have a web shop mate.
Alot of the big traders might hold them in stock too?
Old Jul 2, 2007 | 09:30 PM
Stu @ M Developments's Avatar
PassionFords Creator
Std piston material is fine for 400bhp, dont piss about changing them.
Old Jul 2, 2007 | 09:31 PM
ON-UJAH's Avatar
ON-UJAH
Wiseco are good value for money.
Old Jul 2, 2007 | 09:35 PM
col cos1's Avatar
col cos1
they`ll take a good bit more than that euan
Old Jul 2, 2007 | 09:37 PM
rapidcossie
Should take as much as you can throw at them
Old Jul 2, 2007 | 09:43 PM
Dan's Avatar
Dan
Now THAT'S my kind of talking!
Is low comp needed for 400bhp Stu?
Old Jul 2, 2007 | 09:47 PM
Escos Jam's Avatar
Escos Jam
Cant you just machine your standard pistons??
Jasesapphy's Avatar
Jasesapphy
No Dan
Depends quite a lot on the turbo you plan to use to achieve the power as the turbo will largely dictate the powerband that the power will be achieved at, and thus it makes a massive difference to the cylinder pressures created.
Old Jul 2, 2007 | 09:48 PM
Yes. Thats what at least 90% of the classic 500+ spec engines contain.
Standard Mahle pistons with pockets for cams.
Old Jul 2, 2007 | 09:55 PM
Dan's Avatar
Dan
What turbo would you recommend for 400bhp on a standard engine with uprated headgasket?
Slap me when we meet if thats a stupid question!
Old Jul 2, 2007 | 10:03 PM
Jasesapphy's Avatar
Jasesapphy
I have a RR grauph here from PJ Motorsport (dont know what the rolllers were like for accuracy) but
Standard Compression and Head fully rebuilt with Cometic Gaskets ruuning
T34.63
Greys
Live mapped at NMS
Grp A Coil
Rad Tec Cooler and all the other stuff
402 bhp
Old Jul 2, 2007 | 10:05 PM
Dan's Avatar
Dan
T34.63
Greys
Live mapped at NMS
Grp A Coil
402 bhp
What internals? Standard?
How wide is the power though? Is it laggy on a .63 housing?
Old Jul 2, 2007 | 10:08 PM
bigpower's Avatar
bigpower
Im not going mega, will be something like
Lightened and balanced bottom end, new shells etc
Uprated oil pump
( Poss pistons, if i decide what ??? )
fully overhauled std head possibly with the new Kent cams to Ahmed Spec
T34 / .63 ( cut back blades etc )
500 cooler
breather system
currently on Greens, but may run Black or greys to achieve a 370 - 400?
Any advice greatly welcome
Old Jul 2, 2007 | 10:13 PM
Jasesapphy's Avatar
Jasesapphy
T34.63
Greys
Live mapped at NMS
Grp A Coil
402 bhp
Standard internals, bit laggy with the .63, 4.3K-7K is the good power
Old Jul 2, 2007 | 10:18 PM
Dan's Avatar
Dan
Shite for road then?
Nice spec Karl!
Old Jul 2, 2007 | 10:20 PM
rapidcossie
What makes you think a t34/63 will be laggy?
laggy compared to what? a T3?
I think it would be good turbo for a road car, full boost by 3500 or earlier?
Old Jul 2, 2007 | 10:21 PM
Jasesapphy's Avatar
Jasesapphy
not mega bad, not as bad as a 420 i went in with a 7.2:1 ratio, it was flat, flat, falt then went mental but that spec that he had wasnt bad
Old Jul 2, 2007 | 10:22 PM
Jasesapphy's Avatar
Jasesapphy
.63 is laggy compared to a T34.48 and compared to the gunship of Steves very laggy
Old Jul 2, 2007 | 10:28 PM
bigpower's Avatar
bigpower
Nice spec Karl!
Cheers mate, the engine is all stripped and i want to get everything sorted before the build back up Dont plan to be re doing it anytime soon! LOL
Hopefully going to aim for national day to be my maiden voyage
Old Jul 2, 2007 | 10:32 PM
Dan's Avatar
Dan
Nice spec Karl!
Mine was looking to be Combe for a properly sorted run, think i'll now join you at ND!
Euan, anything is laggy compared to a T3!
Old Jul 2, 2007 | 10:34 PM
Jasesapphy's Avatar
Jasesapphy
Go Blacks and while your getting the chip written go for closed loop and coilpack on a L8,
Thats my only advise
Old Jul 2, 2007 | 11:18 PM
puddy's Avatar
puddy
Does it matter if you use 2 or 4wd pistons(mahle) to machine down?
What sort of ring gaps and piston to bore clearance on em?
I heard cosworth pistons needed lots of piston to bore clearance,high
expansion material used?
puddy
Old Jul 3, 2007 | 04:57 PM
bigpower's Avatar
bigpower
DO i need any uprated low comp pistons??, as today ive had people saying they wouldnt change from std unless i plan 405 - 500 BHP??
God know, each tuner says different
Old Jul 3, 2007 | 05:25 PM
glancy2081's Avatar
glancy2081
ask who ever is going to set the car ups opinion as they will know what works best for the system they use
Old Jul 3, 2007 | 05:44 PM
Dan's Avatar
Dan
Speak to Stu mate, I can't recommend him enough, has been wicked with me and my car over the phone!
Will get up and see him soon for a proper set up! Can't wait!
Old Jul 3, 2007 | 05:47 PM
peteh's Avatar
peteh
i have a set for sale
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Tank Mike
Sep 26, 2015 08:07 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
