Anyone good with Nitro RC Cars??
Just dug my rc car but i need a new cog, but i don`t know where to get one from...
This is the car, if it helps.....
Really want to use it but its pissing me off...
Thanx, Ed.
Thanx, Ed.
try this site or failing that ring a local model shop
http://www.ripmax.com/3index.asp?cat...electedtab=040
yeah as above take it to your lhs as it has to be the right circumference and right number of teeth otherwise the mesh will be wrong and its will shred to pieces every time.
you could still run it as it is by taking that gear off and having it one geared but it would be a little pointless.
Both gears are fucked. I took it to my lhs a little while ago, and they said they don`t deal with these so basiclly there retards
I`ve found the part numbers for both the gears in the manual but does not have a telephone number or website...
Contact Person: Mr. Jimmy Horn
Job Title: Owner/Entrepreneur
Address: 9/7 Calder Place, Edinburgh, United Kingdom, United Kingdom
Zip/Postal Code: EH11 4LR
Telephone: 44-131-2567749
Fax: 44-131-2567749
Or if you want to contact the owner through this website
http://us.my.alibaba.com/mcweb/conta...=2&id=10427241
Originally Posted by wirralphil
Good promt service imo
make sure you gap them properly when assemble the new ones or you will rip em apart again, i normally use a couple rizzla, put inbetween the gears press together line it all up then tighten engine mounts, it just about gives you the right setting
track.focus'd
Aug 12, 2015 05:53 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
