TAPPING FROM 1.8 16v ZETEC!! What can i do???
Old Jun 30, 2007 | 06:18 PM
lickshot's Avatar
lickshot
Default TAPPING FROM 1.8 16v ZETEC!! What can i do???
hey all... my gf has a 1.8 16v zetec silvertop in her mk6 essy cab and think the wrong oil has been put in at some time... not too long back she was complaining of a sort of tappy noise so i checked the oil and yes it was low.. so topped it up but still taps... is it a sticky lifter?? or could it be something more??? would an oil change using the right gear sort it out?? or would it need something a little bit more than that??? only sounds like 1 or maybe 2 lifter??? any idea peeps??
CHEERS!!!
Old Jun 30, 2007 | 06:29 PM
Stephen_B's Avatar
Stephen_B
I actually Bum This Place
Apologies if I'm wrong, but if the oil was really low and the tapping is still there after oil has been added, the damage has already been done. It Could have done in the lifters, possibly more damage elsewhere.
I am no mechanic but that is what I presume would have happened
Old Jun 30, 2007 | 06:43 PM
djmillsy's Avatar
djmillsy
Fife Radge
the oil doent make much diefference i used the chaepest oil around in my zetec and it went like normal and and wasnt load you only need the proper oil for warmup when the oil is thicker
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
