Temp problem with 2wd Saph
Old Jun 29, 2007 | 06:29 PM
DAVE WRC's Avatar
DAVE WRC
Default Temp problem with 2wd Saph
Right all started the other day been out in the car temp was fine never really past half way on the gauge got home and parked up with engine running for a fer mins. all of a sudden the temp gauge shot up so turned engine straight off as i did this steam came out the water bottle
looked under bonnet and i had a split hose got a new hose problem solved or so i thought
filled back up with water etc and started her up all fine left running for bout 10mins still fine temp gauge fine etc thought i would drive round the block got to the end of the road and temp gauge went off the scale and when i say off the scale i mean off the scale
Turned engine off and it stayed there after a few mins the gauge drops well past the lowest mark
Checked under bonnet wasnt really hot and water was fairly cool ?? no sign of overheating
anyone any ideas as i dont wanna drive it gauge was working fine before the split hose episode
any help would be great
Old Jun 29, 2007 | 07:14 PM
crystal cossie's Avatar
crystal cossie
The temp gauge wire is shorting out onto the body giving a false reading, had the same with mine. I cut the end of and crimped a 'BLUE' bullet connector onto the wire, works fine. Worth replacing the switch while your there, be carefull as they can snap off !!!
Old Jun 30, 2007 | 11:11 AM
BIL N KEL's Avatar
BIL N KEL
you might have an air lock as that would cause a false reading on the gauge
Old Jul 1, 2007 | 10:07 AM
DAVE WRC's Avatar
DAVE WRC
Cheers guys think its the sensor wire shorting out in reference to the other thread i have
Cheers for the help
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Harryh24
Aug 26, 2015 07:50 PM
155lee
Aug 14, 2015 11:21 AM
ray barker
Aug 7, 2015 09:00 AM
