Non Starting Escort
Old Jun 28, 2007 | 02:49 PM
Globalgroover's Avatar
Globalgroover
Default Non Starting Escort
After 4 years of virtually trouble free motoring my big turbo escort refused to start last night whilst parked in Sainsburys car park.
Did notice it sounded even more lumpy when cold than usual when I set off, let her warm up for a couple of mins then made the journey completely off boost. Drove into the car park and it dropped onto what sounded like 2 cylinders, dipped the clutch and give it a bit of a rev and it seemed to clear.
Parked up, did my shopping and came out about 30 mins later and nothing. Turns over fine, oil pressure registers fine on the gauge when winding her over and get a good smell of petrol but does not want to fire at all.
Wont have a chance to look at it till Sunday so any ideas of where I should start. Had the dizzy cap off there and then and all looks in good order, played around with wiring plugs to coil, ign amp, crank sensor etc but still nothing. Engine loom connectors have been soldered up.
Any ideas guys
Old Jun 28, 2007 | 04:25 PM
Finny's Avatar
Finny
Hi mate, just had the same prob on mine. I changed the engine temp sensor mate. Did the job straight away.
Old Jun 28, 2007 | 04:59 PM
Rs(555)'s Avatar
Rs(555)
mine did the same refused to start had never missed a beat {big turbo esc} was the map sensor good luck
Old Jun 28, 2007 | 07:06 PM
Ruudsengen's Avatar
Ruudsengen
Made In Norway
I`ve had the same problem. Changed the MAP and everything was OK.
Old Jun 29, 2007 | 02:30 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
mine refused to start so i pm'd Tabetha.
gave him a diagnosis
he reckoned as there was no fuel pump buzzing it may be a sensor
so he said wiggle the wires, did so and BINGO
CheeRS TAB
Old Jul 1, 2007 | 08:18 PM
esko mk1's Avatar
esko mk1
Had the same kind of symthoms with st escos. Turned out to be the cp-sensor. It fooled when warmed enough. Think its differend sensor on bt though
Old Jul 2, 2007 | 06:54 AM
Does it PRIME, if not it is the CPS ot it's connector that needs looking at first.
You should not get a smell of petrol, if you are after continually winding this obviously points to ingition fault, but prime is first thing to look for.
Old Jul 2, 2007 | 07:33 AM
dave green's Avatar
dave green
Had the same problem with mine some time ago as said above if the feul pump dont prime could be as tabetha said, but the fuse box is worth a look , all escorts had fuse box problems
Dave
Old Jul 2, 2007 | 03:06 PM
cosworthbs's Avatar
cosworthbs
mine would not start either,turned out to be the fuse box, tracking across the p c b.
Old Jul 4, 2007 | 07:47 PM
Globalgroover
Default Sorted
First chance I`ve had to look under the bonnet tonight.
Started first time on the key
Oh well, didn`t even have to roll my sleeves up
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
