Fitting new poly track control arm bushs.....
Old Jun 27, 2007 | 10:37 PM
Tarren's Avatar
Tarren
Default Fitting new poly track control arm bushs.....
Got to fit some new powerflex outer track control arm bushs to my Sapph at the weekend
can anyone give me a quick rundown to fitting them please??
Thanks in advance
Old Jun 28, 2007 | 06:23 AM
Easy enough to do, very self explanatory.
Car in air wheels off, you can either undo the roll bar mounts and do both sides at once or one at a time, because of the spring of the roll bar splaying out it can be a pain sometimes to get back in the TCA, just put rear most bush on the roll bar, push into arm, then you can persuade front ones in easier.
Remember to put the weight of the car on the wheels, BEFORE you tighten the anti roll bar/TCA nuts, I do this by lowering onto axle stands.
Old Jun 28, 2007 | 10:28 PM
Tarren's Avatar
Tarren
Thanks mate
done it today it was a pain in the arse but took a deep breath and got it done took nearly 3 hours but i was on my lonesome
Thanks again for all your help mate
Old Jun 29, 2007 | 06:55 AM
You are more than welcome, that is what buddies are for!!
Did it make a big improvement ?
Old Jun 29, 2007 | 12:35 PM
Tarren's Avatar
Tarren
Yes it did mate feels alot more stable and it also sorted out a little wobble i had at 60mph that i couldnt get my head around but as soon as it was done and cheaked everything took it out and drove better than ever
Thanks again mate its a better place with you here
get ready for somemore questions
Old Jun 29, 2007 | 12:37 PM
I only guess anyway!!
Old Jun 29, 2007 | 01:42 PM
Tarren's Avatar
Tarren
You must be a lucky git then....
Because you always get it right
Old Jun 29, 2007 | 02:23 PM
I make mistakes like the next man.
Try a front strut brace for extra stability!!
Old Jun 29, 2007 | 02:47 PM
Tarren's Avatar
Tarren
Jokes aside mate
really appreciate all your help
Thanks
skypeller
Sep 19, 2015 09:58 PM
155lee
Aug 14, 2015 11:21 AM
RIB1122
Aug 12, 2015 08:49 PM
track.focus'd
Aug 12, 2015 05:53 PM
