RS 2000 MK6 / escort gti mk6 rear disk conversion HELP ?
Old Jun 27, 2007 | 12:05 AM
spi escort gti's Avatar
spi escort gti
Default RS 2000 MK6 / escort gti mk6 rear disk conversion HELP ?
Hi i have bean looking to put a rear disk conversion on my escort gti
now i have bean told that the rs2000 rear disk pads calipers and hup will swop over to go on mine is this true ?
1 more question is someone els has said that the 4x4 rs2000 will not fit my gti something about the 4x4 hass a hub and mine has a axel
so if im thinking right thier must be a rs 2000 2 wd witch also has the set up i want to put on the back of my gti
I AM CONFUSED WITH WHAT I CAN USE AND I CAN NOT USE AND WHAT
PARTS DO I NEED AND OF WHAT CAR
PLESES HELP
Old Jun 27, 2007 | 07:10 AM
spi escort gti
CAN ANYONE HELP ?
Old Jun 27, 2007 | 09:04 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
you cant use the 4x4 stuff.
you can use the 2wd stuff tho, but you will need the complete rear beam as the stub axles have a different bolt patter to mk6, unless you can find a mk6 rs2k rear brake setup.
if you can, you need
hubs/stub axles, discs callipers pads and handbrake cable.
if its all off a mk5 then you will need the rear beam aswell
HTH
Old Jun 27, 2007 | 01:57 PM
spi escort gti
thanx alot mate is it a dear job and alot of work ?
Old Jun 27, 2007 | 02:17 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
can get complete beams for around the £150 mark, hand brake cable is sub £20 iirc
pretty easy to change over too
Old Jun 27, 2007 | 03:26 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
If your GTI has ABS then you can't go the RS2000 route. If your car doesn't have ABS then it's a straight forward bolt on job. You'll need a MK6 RS2000 (non-ABS) handbrake cable and possibly (like I did) an upgraded master cylinder.
Some info HERE for the ABS conversion.
Old Jun 27, 2007 | 11:12 PM
spi escort gti
oh god its never straight forward is it
MINE HAS ABS
and im haveing trouble finding a rs2k 2wd
found some on ebay they all asking £200 and they wont post so a caria be £45 i feal the back going to get a good kicking ha ha ha
anything els i need to no before i take this conversion on ?
Old Jun 28, 2007 | 03:44 PM
Dangerous Malcolm..
There's always disc beams for sale on http://www.escortevolution.co.uk/for...db&showforum=6 , but I wouldn't personally go that way with an ABS equipped car. See how much a kit from Pumabuild would cost.
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
RsS2daz
Aug 14, 2015 05:26 AM
sridgett
15
Aug 3, 2015 07:26 PM
Old ford
Jul 31, 2015 06:50 AM
