Twin carbs for xr2...
Been thinking of buying some twin carbs for our xr2 track car... new set is quite expensive. Been looking at some recon second hand ones. Is it worth bothering? what is entailed? do we need to uprate fuel pump etc...?
Originally Posted by smitsturbo
allot cheeper & nicer to go for bike carbs nowadays
if you go on ebay you can pick up a set of r1 throttel bodies for 50 to £80
get a inlet manafold bracket made and if you want loads of bhp get a DTA ecu not cheap but the ecu itself can hold upto 300bhp plus and it controles everything
and you will need make a wireing loom for your car to go in the ecu sounds hard work but not that bad my mate use theses set up on their kit cars /westfields
you should easy pull 40 bhp plus
mk3ste
Oct 17, 2021 10:09 AM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
