Tappety sound ????
Old Jun 26, 2007 | 11:03 AM
Ridgey's Avatar
Ridgey
Default Tappety sound ????
I am getting a tappety sound (quite loud) when traveling at reasonable rpm, eg motorway driving, but no at low rpm. Seems to come as the car warms up.
On startup the car is not unusualy tappety for a cossie.
Is this the tappets knackered ? or would that show when the car is cold and started.?
OR
could this be a sign of camshaft issues, .....the car runs fine by the way.
advise appreciated.
Dave
Old Jun 26, 2007 | 04:06 PM
I would change your oil first to SILKOLENE PRO S 10W/50.
If you are using CASTROL RS 10W/60(?) this will be more prone.
If it still does it after oil change, it could be a number of things but I would try the oil first.
Old Jun 26, 2007 | 06:47 PM
Ridgey's Avatar
Ridgey
Currently on Mobil1 15w50
Old Jun 26, 2007 | 07:09 PM
Mine used 2 b tappety with castrol rs 10/60 changed 2 silkolene 10/50 n now its sweet i wud make sure ur oil pump is making enough oil pressure.
Old Jun 26, 2007 | 08:45 PM
CosKev3's Avatar
CosKev3
Get a proper oil pressure gauge on it at a garage and see what the pressure is m8
If your getting correct oil pressure you will have to take rocker cover off and see if anything is worn/loose
Old Jun 27, 2007 | 06:17 AM
Normaly when tappets r worn or about nackered they normaly rattle from cold.Then they normaly go quiet.
Old Jun 27, 2007 | 06:29 AM
dave green's Avatar
dave green
Its quite common for YB lumps to srip the threads in the camshaft caps
and come loose, seen this a number of times,
Dave
Old Jun 29, 2007 | 08:02 PM
Ridgey's Avatar
Ridgey
Prize goes to Mr Green, 2 studs stripped head on exhaust cam.
Arse.
Got to get it fixed now.
Old Jun 30, 2007 | 01:15 PM
mumbo jumbo's Avatar
mumbo jumbo
helicoil time
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Brickhouse
Sep 23, 2015 06:28 AM
