HELP with brakes
Old Jun 25, 2007 | 05:24 PM
magic randy's Avatar
magic randy
Default HELP with brakes
Anyone know what handbrake cables you use on a mk4 rwd escort with sierra calipers etc ??
sierra ones are too long
Old Jun 25, 2007 | 05:29 PM
NEWTON's Avatar
NEWTON
try a mk 5 rs2000
Old Jun 25, 2007 | 05:48 PM
NUTS RuS's Avatar
NUTS RuS
If it has std Escort handbrake then its the Mk3/4 front yoke and as said above the RS2000 Mk5 rear end. Your better off if you mix the two
Old Jun 25, 2007 | 05:54 PM
magic randy
no its a sierra handbrake
Old Jun 25, 2007 | 05:59 PM
xr4x4rs's Avatar
xr4x4rs
you would need a mk5 rs2000 cable mate
Old Jun 25, 2007 | 06:03 PM
Eagle's Avatar
Eagle
Super Moderator
Originally Posted by NEWTON
try a mk 5 rs2000
Old Jun 25, 2007 | 06:04 PM
magic randy
cool cheers
is that a deffo from everyone cus ill order them tomorrow if it is
Old Jun 25, 2007 | 06:07 PM
crazycage's Avatar
crazycage
Originally Posted by magic randy
cool cheers
ive got a rear engine fiesta ,what disks did you use on the rear?
Old Jun 25, 2007 | 06:24 PM
magic randy
ive used granada hubs discs and calipers
Old Jun 26, 2007 | 01:07 PM
Turby2's Avatar
Turby2
I've used chevette clutch cables in the past in conjunction with Granada / Cossy rear calipers on my rally car. Nicely adjustable as well
Old Jun 26, 2007 | 01:11 PM
turbo's Avatar
turbo
mk5 rs2000 have you converted the car to rwd ???
Old Jun 26, 2007 | 02:15 PM
Eagle's Avatar
Eagle
Super Moderator
you only need the rear part of the cable .. the bit that goes between the calipers...
Old Jun 26, 2007 | 09:10 PM
magic randy
ive ordered the rs 2000 cables now will have to see whether they fit tomorrow night
yeah "turbo" its RWD
Old Jun 26, 2007 | 10:14 PM
xr4x4rs's Avatar
xr4x4rs
i take it your using a sierra handbrake lever?
either way you need to change the half moon clip to the one suited to the handbrake depending on which car it came ff
Old Jun 27, 2007 | 10:59 PM
magic randy
will i fitted the rs2000 cables, had to cross them over from left to right unlike the sierra ones i took off all lined up ok but the handbrake didnt meet up so i made a extender
cheers for your help
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
