Running lean? - with pics
Just bought some better spark plugs and upon changing them have noticed that they are ranging from dark to light in sequence
#1 being the darkest
#4 being lightest
is it running lean? im still running it in, will be getting set up once running in is complete
what would cause this and what can i do to alleviate the problem if it is for the time being? will i still be ok to use it like this til i get it set up in a week or 2?
#4 being lightest
Number four DOES run leaner and hotter that the other three.
Number one richest coldest, progressing to number four hottest and leanest.
This caused by the designof the cooling system mainly and the way the water circulates around number four last after it has picked up heat from the other three.
Your plugs look fine, but by all means have the injectors cleaned tested, it won't hurt.
Originally Posted by Dicko&Sarah
just got a price from local bosch place to get them cleaned and flow checked think ill have to get em done
Phil does it at nice price. Whenever you post them he gets the next day, tests immediately and you get them back the next day. excellent service
Originally Posted by L33 BYT
What was the problem with your engine in the end? I tried to find the post unsuccesfully.
due to the hole in the piston where the gudgeon pin goes through had gone egg shaped
new pistons and little end bushes
the rods were ok
the rods were ok
What they DO tell you is how hot the plug is running - the colder the plug the more black it will appear and the oppisite for a hot plug.
Having said that all 4 plugs should be the same colour....
Alex
Alex
How much more running in you got mate?
Bri.
Originally Posted by tabetha
Plug will tell you mix IF it is the correct heat range.
Look in ENGINE MANAGEMENT, by DAVE WALKER, clear descriptions there.
he goes onto say tuning by plug colour, the colour indicates plug temperature Not Mixture Ratio. and if you fit a colder running plug the carbon will be darker even sooty in appearance, its not rich just colder running, i think most people get side tracked by plug description as in haynes manuals.
Although it does contradict in that say you had a vacuum leak, and the temp increased in the cylinder the plug would change colour and the mixture AFR also? .i think dave w is assuming the engine state of tune is all good.
Regards Dave R.
Indyrs
20
Sep 1, 2015 09:04 AM
kosienutter
31
Aug 22, 2015 09:55 AM
