5th Injector Drivers.....
scort, i'll be running a 5th injector setup with a pressure switch but i'm also going to get an AFC running as well, and the 5th injector will be a little larger than i need. I can then lean out the normal injectors when under 'boost' for a bit of fine tuning, well as fine as you can get on a budget.
I see,
Its for a project. I have a boost retard unit. Its for a janspeed sierra.
If i had a tell tale light on the dash, coming on at the same time as the injector, then it would act as a safety mechanism.
What is an AFC?
Steve
What is an AFC?
Steve
air fuel controller...
basically, as far as i know it just manipulates the air flow signal to the ECU, tricking the ECU to either run lean/rich at specific RPM's and throttle position etc.. I was thinking i could just switch the airflow signal in and out between the original one and the AFC one using the pressure switch.
hope that makes sense.
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
