PETROL IN MY OIL?????????
Just undone the sump plug to drain the oil and there was petrol mixed with the oil.(very runny oil and a strong smell of petrol)
What could cause this?
P.S:The car has been standing for 6 months.
Have had problems with the FUEL METERING UNIT.I:E Loads of petrol being chucked into the engine and flooding.Just wondered how it gets into the sump??
Don,t need a serious problem right now.
Originally Posted by abdr500
mercury grey minter
piston rings as they have a ring gap and thats were its lost through
So are my rings f*ked or is it just unburnt fuel that gets through being thinner than oil??????
mercury grey minter
Don't leave it like it for too long though
it'll either be overfueling when you parked it up and the bore wash will have sent the excisive fuel down past the rings
or
if you've been letting it run up then the cold start could have been leaking and just dumping fuel into the chambers which is getting pushed past the rings
i had an injector out and it was pissing fuel through the turbo and exhaust
which turned the 3 door into a bonfire
or
i have this problem. Its urgent! its a matter of maybe buying a new engine which i really cant afford. Is this sorted buy adjusting the metering unit? Would this cause the compression to die? I appreciate it wouldnt be tuned but would it stop the problem? thanks
deathrider666
Sep 28, 2015 06:12 PM
