series one rear brake conversion to discs
Old Jun 24, 2007 | 07:44 AM
PDH11R's Avatar
PDH11R
Default series one rear brake conversion to discs
can any help me the all the info i need to change the rear drum to discs.if i do this what holds the caliper on and looking at the drum it is a lot deeper than a dics does it have to be space out.does any one sell the full fitting kit
Old Jun 25, 2007 | 09:20 PM
MikeyXR2i's Avatar
MikeyXR2i
You would need a Hub made for the wheel bearing. Mounting Plates for the caliper carriers. Mine on my 2i needed spacing but not much.
You'd need a handbrake cable also. Nice set of braided lines to.
Old Jun 25, 2007 | 11:38 PM
smitsturbo's Avatar
smitsturbo
MikeyXR2i i got a rear disc setup from burtons but i never got no hub made for wheel bairings i dont think
Old Jun 26, 2007 | 06:19 AM
MikeyXR2i's Avatar
MikeyXR2i
Yeah, its the bit that the wheel bolts to with the studs sticking out,(saying that its an S1 so would be wheel bolts) and the bearings in the middle.
Old Jun 26, 2007 | 11:25 AM
SafeChav's Avatar
SafeChav
You use the same hub that the drum previously screwed to!
You just need the conversion brackets, calipers, brake lines and a mk5 RS2000 handbrake cable.
And as for spacing, you'll find the discs push your wheels out further than previously so you will get issues with rubbing if you have big wheels
Old Jun 26, 2007 | 07:56 PM
MikeyXR2i's Avatar
MikeyXR2i
Ahh didn't know you could use your original hub.
On My fiesta the studs were built into the drum (no hub).
But of course S1 Different
I used an RS2000 cable also.
Old Jun 26, 2007 | 08:56 PM
PDH11R's Avatar
PDH11R
will it move the wheel out much
Old Jun 26, 2007 | 09:09 PM
SafeChav's Avatar
SafeChav
enough to make a significant difference if you have big wheels, if not it wont be an issue
SmudgerByName
52
Jul 28, 2016 06:14 PM
mint_s2
Sep 2, 2015 08:58 AM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
