blue smoke not turbo or is it
hi i have a smoking problem when i start the car in the morning it smokes out the back blue smoke that oil i no but after it warms up and left runnig for ten min it clears up and then thers no smoke but if you hold the revs up about 6 000 rpm then it will start smoking agine and if you come off the gas after a few moments it stops smoking it only smokes if you rev it hard and in morning or once left for a few hours could that be stem seals or would that smoke all the time i cant see it being rings as oil isnt comieng up through the pisston ring when engine is off so oil is defo coming down from top or leaking out of turbo i disconected the turbo oil fed pipe and it still smoke so that ruels out turbo ....so is it rings or stem seals is ther any way of testing steam seals with out taking off the head
Not to up on this but you could do a compression test to try and rule out rings!, don't think stem seals are that bigger deal to change, so that be done after the compression test if all is well there, then see how it's getting on.
comprission is all good but number 4 is 2 bar lowere then the rest all the others are at 8 bar and number 4 is betwwen 6/ 7 bar so it s not that much off a differance pisston rings were changed about 900 miles ago and it had new steam seals 900 miles a go to so i donot no weather to strip it all down and do it all from scratch then i now its done proper but a ring could be fucked or steam seal could of lefted or split dont mind doing the work just liked to now befor i do any work
Matt Baxter
Sep 16, 2015 08:30 PM
The Enigma
13
Aug 20, 2015 09:38 PM
