4x4 coilovers on 2wd
Old Jun 23, 2007 | 06:21 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default 4x4 coilovers on 2wd
what is needed to fit 4x4 front coilovers to my 2wd cossie
thanks
Old Jun 23, 2007 | 06:23 PM
costina's Avatar
costina
Live long and prosper!!
Won't fit as the hubs are different the 4x4 ones are bigger i think
Old Jun 23, 2007 | 06:25 PM
dave cos4x4's Avatar
dave cos4x4
you need 4x4 hubs.
you can get a sleeve made to mae then fit,or is that the other way around....2wd onto 4x4 or 4x4 onto 2wd.
Dicko&Vacant
so will i only need a set of 4x4 front hubs?
Old Jun 23, 2007 | 06:27 PM
dave cos4x4
all the same everywhere else, just where they sit in the hub,the hole is too big or too small...not sure.
one will go into the other though with a sleeve.
just buy 2wd coilovers.
Old Jun 23, 2007 | 06:30 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
the only thing different is the actual damper tube if they are bilstiens,everything else is the same,so all you would need is a pair of 2wd tubes,the insert etc will all fit into it.
Old Jun 23, 2007 | 06:34 PM
costina's Avatar
costina
You could use 4x4 hubs but u will need to have the end of the shaft still in there so extra weight
Old Jun 23, 2007 | 07:47 PM
As said 4wd ones thicker tube.
Old Jun 23, 2007 | 08:36 PM
The Youth.'s Avatar
The Youth.
dicko, speak to rob he fitted some to his sierra using a sleeve to make the gap up, or if there cheap let me buy them for the track car!!
**edit** ignore that bollox above rob fitted 2wd ones into a 4x4 hub, he might do a straight swop tho!!!
steve
Old Jun 23, 2007 | 09:51 PM
lamb chops's Avatar
lamb chops
Or get your hubs machined out I have a set for sale
Old Jun 23, 2007 | 10:06 PM
Micky The Finn
Former Sponsor
but they would be rather thin would they not?they are essentially a stressed clamp,i wouldnt like to risk that!
mark r
Sep 29, 2015 07:27 PM
rog
Sep 16, 2015 03:00 PM
tib2220
Sep 14, 2015 12:33 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
