-31 actuator benefits
Old Jun 23, 2007 | 06:05 PM
syko2005's Avatar
syko2005
burning oil
Default -31 actuator benefits
ive been offerd a collins -31 actuator for my s1 what are the benefits of fitting one of these will it be noticeble thanks
Old Jun 23, 2007 | 07:15 PM
rsdan's Avatar
rsdan
Default Re: -31 actuator benefits
u will be able to run more boost.
Old Jun 23, 2007 | 07:37 PM
syko2005's Avatar
syko2005
burning oil
thanks i wasnt really after more boost. but ive read some where that the boost comes in harder when running a -31. is it a good upgrade to get
Old Jun 23, 2007 | 08:11 PM
s2 ben's Avatar
s2 ben
one of the best mods you can do to start of with
Old Jun 23, 2007 | 08:57 PM
rsdan's Avatar
rsdan
i have one for sale.
Old Jun 23, 2007 | 09:30 PM
JamboRS's Avatar
JamboRS
focus rs 1672
not true,boost does not come in harder as the lift off pressure is still the same
Old Jun 24, 2007 | 11:06 AM
syko2005's Avatar
syko2005
burning oil
well i brought the -31 actuator and fitted it this morning. theres deffinetly a diifernce compared to my standard but i think that might be something to do with the extra boost it seems to be running. i guess the car isnt chipped as it seems to be hitting the boost limiter at about 15 heres a pic of my boost guage i am reading it right arnt i the 15 is 15 psi thanks
Old Jun 24, 2007 | 12:13 PM
s2 ben's Avatar
s2 ben
yes that is 15 psi but i think it is chipped as it would cut at about 10.5 does it hold 15 psi
Old Jun 24, 2007 | 01:53 PM
syko2005's Avatar
syko2005
burning oil
hi i cant really tell with the weather being bad if it will hold 15 psi or if it goes a bit higher due to the rain it just keeps spinning up like mad. it might be creeping over that but its definetly hitting the boost limiter about 15. i only have a pipe connected from my actuator to the compressor so ive been out and brought a 2 way bleed valve so i can adjust the boost down a touch and see if it holds there ok. am i right in thinking if the bleed valve is screwed in it will lower the boost thanks
Old Jun 24, 2007 | 05:58 PM
s2 ben's Avatar
s2 ben
yep in to lower it
Old Jun 24, 2007 | 06:12 PM
syko2005's Avatar
syko2005
burning oil
il get it sorted in the week hopefully the rain will go away and we will finaly get some summer if it will hold 15 psi will that be a safe enough level of boost. the engine was rebuilt 3000 mile ago and it has a hybrid turbo thanks for the advise
Old Jun 24, 2007 | 06:18 PM
s2 ben's Avatar
s2 ben
what intercooler is on your car if standard imo 12 psi would be best although to be honest i think you will be better of taking it for a setup its not just a case of putting a bleed valve on and running x amount of boost that is what alot of peaple do and then moan that rst are unreliable always blowing up etc
Old Jun 24, 2007 | 06:39 PM
syko2005's Avatar
syko2005
burning oil
its running a standard intercooler. definetly going to get it set up. just done a service on it this weekend before it hits the rolling road
Old Jun 24, 2007 | 06:57 PM
s2 ben's Avatar
s2 ben
nice one
Old Jun 24, 2007 | 10:52 PM
JamboRS's Avatar
JamboRS
focus rs 1672
you cant adjust the boost down,a bleed valve bleeds air to up the boost,you have it set at 15psi actuator pressure,youll need to unscrew the actuator to reduce the boost
Old Jun 25, 2007 | 05:45 PM
syko2005's Avatar
syko2005
burning oil
you cant adjust the boost down,a bleed valve bleeds air to up the boost,you have it set at 15psi actuator pressure,youll need to unscrew the actuator to reduce the boost[/quote]
been doing a bit of reading up and have noticed this im going to wind it out back to the 10psi it was running and then take it to be rolling roaded and set up i think thanks for the advise
steve.rst
Mar 15, 2016 08:01 AM
Fezman1
Oct 2, 2015 01:22 PM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
Adam Graham
Sep 6, 2015 06:04 AM
