200 bhp
Old Jun 23, 2007 | 04:32 PM
djmillsy's Avatar
djmillsy
Fife Radge
Default 200 bhp
ive decided to rewire and rebuild my car after months of problems. basically what do i need to get 200 bhp from the car and keep it reliable if there is sure a rs turbo
Old Jun 23, 2007 | 05:20 PM
T28 RST's Avatar
T28 RST
Ok then
Chip
-31
16psi
Decent cam
Grs or similar full front mount intercooler
Magnex, Mongoose exhaust
Proper set up
Maybe an uprated clutch depending on the condition of yours.
Service it reguarly and it will last forever
Old Jun 23, 2007 | 06:16 PM
dissmalrs's Avatar
dissmalrs
hi there mate mine is 198.2 and is running 18 pis 285t2 cam pro alloy fruntmount intorcoller and an armed bajoo chip was setup at gs motorsport and a oil cooler 2 keep it a bit safer but everthing els is standard
never had any probablams in the 4 year it has been running and i have had it a wile now and it is sweet as a nut
hope thats a help
darryl
Old Jun 23, 2007 | 08:32 PM
djmillsy's Avatar
djmillsy
Fife Radge
hope thats a help
darryl
alright mate what sort of costs were invoolvoed
Old Jun 23, 2007 | 10:22 PM
T28 RST's Avatar
T28 RST
Ok then
What parts you got on your car at the moment.
Intercooler will be 350 - 400
Exhaust - 300 - 350
Cam - 250 - 300
Clutch - 250
Proper set up - 100
Assuming the car is already chipped.
Old Jun 23, 2007 | 10:43 PM
djmillsy's Avatar
djmillsy
Fife Radge
not sure if car is chipped noy had the ecu off to check got the exhaust its long term plans mate
Old Jun 23, 2007 | 11:11 PM
T28 RST's Avatar
T28 RST
Ok then
What boost does the car run
Old Jun 23, 2007 | 11:21 PM
djmillsy's Avatar
djmillsy
Fife Radge
standard i have old printout for 184 bhp though
Old Jun 23, 2007 | 11:33 PM
T28 RST's Avatar
T28 RST
Ok then
Is it totally standard apart from the exhaust, if it is, its not going to make 184 with standard boost
Would be lucky to make 140 with just an exhaust
Old Jun 23, 2007 | 11:43 PM
djmillsy's Avatar
djmillsy
Fife Radge
i know that its got -31 actu, a hybrid turbo and a 195 chip in it going by the reciepts ive not had it apart to check it yet just wanting to know what is needed
Old Jun 25, 2007 | 03:30 PM
dissmalrs's Avatar
dissmalrs
Exhaust - 300 - 350
Cam - 250 - 300
Clutch - 250
Proper set up - 100
glad u put them up mate was not shure about the price i was going 2 look through the all th e stuff from burtons as thats were i got the car from
but the clutch was 140 ap plate and i got a ap clutch cover for nothing off a mate at burtons
and mine has an ally ras as well so itcam with theintorcoller and fans
but that is about right i think
cheees darryl
Old Jun 25, 2007 | 04:52 PM
djmillsy's Avatar
djmillsy
Fife Radge
i dont want to modify my pedal box and taht so i think ill go 180 bhp whats needed for that
Old Jun 25, 2007 | 04:56 PM
T28 RST's Avatar
T28 RST
Ok then
The same parts that are listed above
Old Jun 25, 2007 | 08:17 PM
SafeChav's Avatar
SafeChav
Really hope this works out well for you mate.
I'm not completely sure ripping it all out and trying another method is going to solve it for you though......surely it'd be better to identify the exact fault and then find the best solution?
Old Jun 25, 2007 | 09:28 PM
djmillsy's Avatar
djmillsy
Fife Radge
yeah i know but im going for the full resto so might as well up the power
Old Jun 25, 2007 | 10:55 PM
SafeChav's Avatar
SafeChav
yea but u could spend all that money and still find it wont even start!!
I just cant help but think you're guna blow a wad and still have problems mate
Old Jun 26, 2007 | 05:38 PM
djmillsy's Avatar
djmillsy
Fife Radge
i kmow nut im going to renew alot of things the loms ive got is murder ive got 8 connections on the bat and a live feed to the relay so im going to do the loom and welding then rebuild my old engine
Old Jun 26, 2007 | 05:43 PM
SafeChav's Avatar
SafeChav
8 connections for what exactly?
Chances are its just things for alarns/flashy lights/fan over ride and so on.
Old Jun 26, 2007 | 06:07 PM
djmillsy's Avatar
djmillsy
Fife Radge
thats it a dont know my looms got more joints than a stonners convetion
Nov 1, 2015 06:53 PM
chowfornow
Alloy wheels and ICE for sale
15
Oct 17, 2015 07:09 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
Marv888
Sep 26, 2015 03:44 PM
