F.A.O Tuners, big spec owners
Morning all,
its well documented about tuners in the uk, and their credentials, however, if hypertheticly speaking someone took their motor to them and said i have 10k for you to make this into a very fast track/road car, who would you first phone?
I know you cant have a good track car and a good road car but a good comprise is hypertheticly what im after.
Please can someone advise me or tuners feel free to PM me with their answers.
I am not online mon-fri as changed jobs and this does not have the internet available for me.
Many Thanks for your time.
P.S this 10k has to include box clutch diff etc etc. NO particular speak in mind as of yet, if you have some ideas then please let me know. My car is 1989 2wd with a good solid shell.
Luke
My Mobile is 077952 46105 if you want to speak to me, no pranks
Luke
Originally Posted by 4x4 ste
It all depends on what you term as big spec because if you want 500 plus bhp 10 k will be spent on a decent engine and not much else
just stage 1 mate, nothing special
if i had a cossie & i was in your situation i would speek to julian godfrey as i remember reading some where that he does very good deals for roundabout the 10K mark
he does built race cars but he must make drivable ones also,
http://www.racetuners.com/
10k on an engine tho will give you an engine that the car can't cope with.
think handling and braking ,then whats left spend on some milder tuning or picking up a good deal on a built engine.
to go from stage one to 500 bhp is quite a step in a rwd car if you are not used to it. late 300's or 400bhp would be a better start
i did say originally that the 10k will have to include everything, unles si forget to type that bit!!I spoke to Mike about six pots about a month ago, and danny B will sort me out with everything else, (if i ask nicely) lol
To give you an idea:
6 pots Ł1500
Coilovers Ł1100
Diff Ł1000
Radiator Ł250
Intercooler Ł350
Clutch Ł350
Gauges Ł250
Fuel pumps Ł300
braided lines Ł200
Re-map Ł500
Theres nearly 6k then theres the engine gearbox and fitting plus cage if you want one
6 pots Ł1500
Coilovers Ł1100
Diff Ł1000
Radiator Ł250
Intercooler Ł350
Clutch Ł350
Gauges Ł250
Fuel pumps Ł300
braided lines Ł200
Re-map Ł500
just try buy every thing second hand, im sure if you look all over the forums & ebay there are loads of stuff to be found, plus you dont lose as much if you come to sell it or break it
If I had 10K to turn a stnadard car into a track car I would spend maybe 3K tops on the engine, and that would basically be to get it to a good stage 3 setup and a very good service (including things like head gasket), Id spend nothing at all on the gearbox if its working ok, get a paddle clutch.
Decent diff, decent rear beam, coilovers, and a really good set of brakes and a set of 888 tyres or similar
You then have Ł6.5k buy the turbo and all ther other bits you will need to run that sport of power.
Originally Posted by Chip-3Door
Actually everything above is a lie, if I had free choice I would sell the saph for 5K and spend 15K on a lotus or caterham that was already track prepped probably, LOL
always the optimist chip
it might be a good idea to take you money and run while you still can!!
Your 10k should go on suspension, brakes and a new rear beam and arms for a start!
I think what you need to do is sit down and have a good think about what you want to do with the car.
Eg: I want mine for trackdays and fast road use, so i decided that instead of going for 500bhp+ i would go for around 400bhp. Then concentrate on the suspension set up, Brakes, Diffs etc.
Originally Posted by cossie4i
I think the KEY thing here is to get your head round the fact that round track a 330bhp saph with the right suspension will wipe the floor with a 500bhp saph that doesnt have, and more importantly, it wont break doing it!
Nah, keep the saph for the road and buy this
http://www.pistonheads.com/sales/175957.htm
As if you try to use the same car to do everything, there will be too many compramises.
Steve.
