engine boffins
we are building a 2.0l zvh and i need to know how much to dec the pistons by to get the desired 7.8.1 comp ratio
bore is 84.7 mm
head is 129mm thik
pistons are accralite blanks so machining is necessary
thanks for any help given
bore is 84.7 mm
head is 129mm thik
No one can just tell you how much to take off it depends on lots of things its best to take it all to an engine builder who can measure things, for example the measurement might be different form centre of gudgin pin to top of crown than what someone else has used so they tell you to take 1mm off like they did and it could be miles out, better to be safe than sorry.
i aint taking the piss mate just thought that some one might have done the same thing with same pistons and some wher around the same thikness head or i could just check the pistons against the oe ones as they need .5 taken off to get them where they need to be so thats one way ore i could mesure the fluid way the head chambers and work it out from that
Originally Posted by Roosie
what pistons didi u use coswurv?
its cos l6 mate so fueling aint a problem
