are rst cps sensor interchangable?
500bhp Cosworth in making
need one for my rs as i have the hole there but can only find zetec ones will these fit cvh engines? if not anyone got a cvh one?
the zetec sensor is a short stuby little thing and a frst/efi cvh uses a long sensor
zetec one wont register as its too far away from flywheel
cvh one you need the bracket that goes on the block for the cps to go too
if you dont use the bracket the cps is to long then and the flywheel will chew it up
i also think that the 2.0 dohc injection from sierras sues teh same cps as a cvh
well all mine dohc has used long sensors
on the cvh thers a little cylinder type bracket
the bolt for this bracket goes in from flywheel side
then the cranksensor goes into this block into the flywheel
dont know if ford do them or not
be easier to go find a efi cvh down the scrappy
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
