Cosworth Cam Cover Gasket.
Old Jun 22, 2007 | 06:42 PM
jpbaginski's Avatar
jpbaginski
Default Cosworth Cam Cover Gasket.
Just fitted a new cam gasket and half moons (comitec) but getting oil leak from the front of the cam cover.
Should I also have used sealent with the gasket?
Also around the gasket it feels wet but not leaking this was not like this before.
Advice please......
Old Jun 22, 2007 | 06:50 PM
abdr500's Avatar
abdr500
yes i all ways use sealer on the front were the half moon and the gasket meet .are you sure its not leaking from the cam oil seals
Butch.'s Avatar
Butch.
you need to put a bit of silicone at the bottom of each half moon as they always leak from there
Old Jun 22, 2007 | 06:53 PM
jpbaginski's Avatar
jpbaginski
how tight should i do the bolts?
also what about sealent all around the gasket?
Old Jun 22, 2007 | 06:55 PM
abdr500's Avatar
abdr500
no need for sealer any were else just use it at the front ..bolt it down evenly don't tighten 1 up all the way and move down do it gradually
Old Jun 22, 2007 | 06:56 PM
Jim Green's Avatar
Jim Green
Don't use sealer on the gasket....just the ends of the half moons.
Old Jun 22, 2007 | 06:57 PM
coswurv's Avatar
coswurv
Just normal instant gasket from your local motor factors mate, put a bit on the head where the half moons sit then push them in and squeeze a bit in each corner where the half moons meet the gasket, refit cam cover and wipe off excess job done.
Kevin B's Avatar
Kevin B
I would say as tight as 'feels' alright - bare in mind you are tightening in to alloy though, so dont use all your strength!!
Old Jun 22, 2007 | 07:00 PM
jpbaginski's Avatar
jpbaginski
Ok.
What about around the half moon too.
Old Jun 22, 2007 | 07:19 PM
jpbaginski's Avatar
jpbaginski
OK everyone I will try this on sunday THANKS>>>>
Old Jun 22, 2007 | 07:22 PM
dave cos4x4's Avatar
dave cos4x4
tighten them up as you would with a cylinder head sequence.
Old Jun 22, 2007 | 07:45 PM
SapphyMike's Avatar
SapphyMike
get a fibre gasket from mike r!!!
jessie_rs
11
Jun 3, 2019 04:57 PM
3i Jim
Nov 20, 2015 05:12 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Aug 14, 2015 07:29 AM
