Dog Box Question
Old Jun 22, 2007 | 11:53 AM
Ex-Finesse's Avatar
Ex-Finesse
Default Dog Box Question
As far as I understand them, dog teeth spin the next cog at the same speed as the one currently transferring the drive, so instant clutch-less shifting is possible.
In my mind, this works fine with a sequential box, but I don't understand how it could work for a standard H-pattern box.
If anyone could clear this up, I'd be grateful
On a similar note, has anyone heard of Tranex gearboxes?
Thanks,
Ralph.
Old Jun 23, 2007 | 11:37 AM
Ex-Finesse's Avatar
Ex-Finesse
Maybe the Q isn't clear enough:
How does a Dog Box work when it is in an H-pattern format?
Old Jun 23, 2007 | 12:10 PM
ian sibbert's Avatar
ian sibbert
Dog gears dont spin anything up, they simply replace the syncro rings in a standard gearbox and rely on the engagement slamming into each other one side has a castliation the other is machined to accept the castleation with a degree on elonagation to help enagement, unlike a standard syncro cluster which slows the hub down before carrying out a smooth enagement.
There are numerous configuarions of dog boxes and some work better than others....as an example quaife used a large 3 dog change then evolved to a 6 dog to try and improve change quality....number of dogs, quality of material, design of the cluster all go towards improving the operation of a dog box.....
They operate in exactly the same way mechanically whether they are sequential or H pattern.
Dog boxes require a high level of maintenance as the dogs wear, but they provide substantially less loss of engine power transfer than a standard as the change is carried out without having to slow the box down to change gears...
HTH
Ian
Old Jun 23, 2007 | 12:38 PM
Ex-Finesse's Avatar
Ex-Finesse
That does help, thanks
As the shift time in an H-pattern is longer than if in sequential format, do you have to reduce the throttle to avoid the engine and gearbox spinning up quickly whilst between gears, which would wear the dogs faster?
I've searched for Tranex boxes but have found little
It needs a crown wheel and pinion, and I don't want to find they went under years ago...
Old Jun 23, 2007 | 03:43 PM
ian sibbert
Yes and no....with the dog box we never clutch going up the box and with the FFD I never usually clutch going down....even with sequential, without gear cut, flat change (torque reduction) software/hardware you would still need a small amount of off throttle time to allow a change...
Tran-ex are a small company you produce excellent gear kits....they are still in existance...
http://www.tran-x.com/gearboxHTML/gearboxHome.html
Ian
Old Jun 23, 2007 | 05:01 PM
Ex-Finesse's Avatar
Ex-Finesse
Thanks very much for your help
liamT74
Sep 23, 2015 10:24 PM
chowfornow
Sep 19, 2015 10:47 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
Rizlablue
Sep 6, 2015 10:54 AM
