CROSS OVER PIPE?????
Old Jun 21, 2007 | 09:44 PM
mercury grey minter's Avatar
mercury grey minter
Default CROSS OVER PIPE?????
Will a FIESTA RS TURBO cross over pipe fit on a 90 spec ESCORT RS TURBO with the original escort boost pipes???
Old Jun 21, 2007 | 10:17 PM
T28 RST's Avatar
T28 RST
Ok then
Im sure the small hose that goes between the inlet to crossover is a different size
Old Jun 21, 2007 | 11:29 PM
djmillsy's Avatar
djmillsy
Fife Radge
the pipe is a different shape and so have longer lugs on them
Old Jun 22, 2007 | 08:44 PM
Turbo-Beal's Avatar
Turbo-Beal
That correct you will need to buy a 70mm diameter peice of hose to fit over the crossover pipe and EFI throttle body. Thats assuming you have an EFI inlet manifold? As your rocker cover should be 90 spec you can use the standard rocker cover as they come with the wider lugs and are the same as the fiesta ones. The other boost hose should fit with a bit of persuasion.
Cosnada
Jan 7, 2016 05:30 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mpilk
Sep 27, 2015 09:21 AM
